Re: best spot to pull vacum from on b1 motor
[Re: camastomcat]
#2675489
07/08/19 11:51 AM
07/08/19 11:51 AM
Posts: 43,228 Bend,OR USA
Cab_Burge
I'm having the same problem on my new 440-1 motor with Jesel paired shaft rockers with both pushrod oiling and spray bar oiling. I mounted the Moroso vacuum pickup fitting on top of the passenger side valve cover and added a baffle to help stop the excessive oil being pull into the puke tank, mine is pulling about 2-4 ounce per run. I have to drain the tank after 3 runs, if I don't it will start dripping out the puke tank push on breather The same setup on the old motor last year would not do this hardly at all, mainly it would pull water condensation out of the same location with a different fitting That motor has a set of Harland Sharp single shaft rockers and no push rod oiling Not trying to hijack but all help appreciated
[Re: moparmatt0]
#2676011
07/09/19 03:02 PM
07/09/19 03:02 PM
Posts: 4,209 New York
polyspheric
New York
Is possible, the VC opening and the first section of tube should be large and as close to vertical as you can - this reduces the air speed and allows droplets to fall back. After some distance the smaller tube is less important.
Boffin Emeritus
[Re: moparmatt0]
#2693583
09/02/19 09:08 AM
09/02/19 09:08 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
