Page 1 of 5 1 2 3 4 5
HEMI guys..... aluminum MP heads #2673046
07/02/19 01:56 PM
07/02/19 01:56 PM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
Just saw a FB post with a “what is it worth” P4876857.... I ran the part number and it superseded to a P5153875 which there are 11 of at 5 different dealers across the country. Dealer cost around $1200. When they’re gone, they’re gone!
*while I’m not a “parts guy” I believe my search via dealer connect to be accurate...
Re: HEMI guys..... aluminum MP heads [Re: J_BODY] #2673107
07/02/19 03:32 PM
07/02/19 03:32 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
They are a bad deal at any price. Edelbrock Victor Jr is the same price as what it would cost to make them as good.
2011 Drag Pak Challenger
Re: HEMI guys..... aluminum MP heads [Re: rickseeman] #2673152
07/02/19 03:46 PM
07/02/19 03:46 PM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
So they’re “junk” basically..... maybe why they’re still on shelves. If that were true there should be W5’s and Stage VI heads out their too! laugh2. Perhaps the hemi guys know better and the wedge and small block guys were just a glutton for punishment smile
Re: HEMI guys..... aluminum MP heads [Re: J_BODY] #2673154
07/02/19 03:57 PM
07/02/19 03:57 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I believe the “P515” numbers are the Edelbrock made stock type head.
I’ve done a few set of these....... they’re pretty nice heads IMO.
Way nicer than the MP stuff they replaced.
Maybe if MP stops selling them, Edelbrock will start marketing them as an “RPM” head.
I like the Victors, but I don’t think it’s the best choice for all hemi applications.
Re: HEMI guys..... aluminum MP heads [Re: J_BODY] #2673158
07/02/19 04:00 PM
07/02/19 04:00 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Rick, just what is so bad about them? Are the castings poorly done, or is it the quality of the hardware? It sounds like if you got a set for free, you would use them for trot line weights. LOL What is the story?
Re: HEMI guys..... aluminum MP heads [Re: J_BODY] #2673163
07/02/19 04:02 PM
07/02/19 04:02 PM
an8sec70cuda Offline
I'm not sure which part number my aluminum MP hemi heads are, but they've served me well. They were new sometime around 2004-2005.
The guides are soft, but other than that I've had no problems w/ them. Been running them since 2006.
The casting on mine is 2531110-M
CHIP
'06 GMC 2500HD LBZ Duramax
Re: HEMI guys..... aluminum MP heads [Re: J_BODY] #2673169
07/02/19 04:04 PM
07/02/19 04:04 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Because of the price on the Edelbrocks, (and the flow) they made every other head obsolete for performance applications. The head you are talking about would be fine to put on a stock Street Hemi cruiser.
Re: HEMI guys..... aluminum MP heads [Re: Lee446] #2673197
07/02/19 04:22 PM
07/02/19 04:22 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
There is nothing wrong with the heads in a stock power application. I've had them and used them. The problem (for a performance based application) is the price of the Edelbrocks. $2,600 (or whatever they are today). If somebody gives you a new set of the heads in question, you will have to UPS them somewhere, have them ported and larger intake valves installed to get to the 430 cfm that the Edelbrocks flow out of the box, and shipped back to you. Your bill will be close to $2,600. Now do you see the problem? Victor Jr's are a game changer.
Re: HEMI guys..... aluminum MP heads [Re: rickseeman] #2673283
07/02/19 05:02 PM
07/02/19 05:02 PM
My MP heads flow 430 cfm w/ the stock size valve. The Edelbrocks are a great head, especially for the money. I spent over a grand having MCH cnc port my MP heads. Wish they were available back when I built my hemi, but there weren't as many options back then.
CHIP
Re: HEMI guys..... aluminum MP heads [Re: an8sec70cuda] #2673399
07/02/19 10:11 PM
07/02/19 10:11 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
If you want a stockish head (or say one for a 472) The Stage V's are better quality and look original to boot, they used to be around $2k a set bare, I haven't priced them lately.
Sheldon
Re: HEMI guys..... aluminum MP heads [Re: RUNCHARGER] #2673419
07/02/19 10:59 PM
07/02/19 10:59 PM
Superfreak
Superfreak
$2500US
Re: HEMI guys..... aluminum MP heads [Re: ] #2673548
07/03/19 11:36 AM
07/03/19 11:36 AM
So. Burlington, Vt.
So. Burlington, Vt.
Stage V heads are very nicely made pieces....... but...... the bare ones that have been sent to me are fairly labor intensive(unfinished guides and seats) and if you want to get something back that’s “ready to bolt on”, you’ll have several hundred $$ in parts on top of the labor.
For the hot street, street/strip type build using smaller bores and less than 500 cubes, I like the Ede made MP heads.
Mancini shows assemblies at $1485/ea.
Re: HEMI guys..... aluminum MP heads [Re: fast68plymouth] #2673609
07/03/19 02:19 PM
07/03/19 02:19 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
P4876 is (was) Cummins. 110-M casting number.
They machined 'em.
Have fun, read between the lines and Come to your own conclusions, I guess wave
The superseded P515 is Edelbrock. 110-M1 and I believe M2 (showing a little Mopar humor) casting number.
Supersessions usually happen for a good reason....
The head were talking about is one of the items MP management (of the 2008 timeframe) replaced
based 100% on customer input. Same managers who did the world block, the aluminum 452 wedge
Head, the wedge branded rpm intake, and alot of other very worthwhile projects.
Some effort went into it.
I guarantee more would have happened for the good, had the same staff stayed on.
Is P515 NS1?
If it isn't, then I'm not sure what to make of "when they're gone they're gone" (unless referring back to the p4876 stuff)
Rich H.
Esse Quam Videri
Re: HEMI guys..... aluminum MP heads [Re: ZIPPY] #2673729
07/03/19 06:26 PM
07/03/19 06:26 PM
montana
BANDIT Offline
BANDIT  Offline
montana
I thought there was some seat falling out issues with the early ones?? Sent the set I had in and had new seats installed, made them a little pricier. Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: HEMI guys..... aluminum MP heads [Re: ZIPPY] #2673772
07/03/19 08:27 PM
07/03/19 08:27 PM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
You’re the end of the MP era Zip.... cool insight. They changed up the parts page and I didn’t note an NS1...familiar with that code of death from looking for R3s. Guess I brought that “ASSumption” on myself looking at the current administration and the fact this old stuff is dying. I was like “WOW” that there was still a performance part on some shelves laugh2
Re: HEMI guys..... aluminum MP heads [Re: J_BODY] #2673780
07/03/19 08:53 PM
07/03/19 08:53 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Well, thank you. Been out since 2013 but this stuff is in my blood.
I'd consider going back under perfect circumstances (probably never happen).
There are many great running vehicles out there with Cummins machined heads.
Chip's car comes to mind! So they are not at all horrible products, but it's smart to have
Them checked and gone through.
The p515 are just more user friendly, like most Edelbrock products.
I really have to hand it to them.
They only have to hire and empower one or two qualified folks who cares, and are pissed off and driven enough to force
the changes needed. I know someone who....I'm fairly confident....could fix the whole block supply issue in probably less than a year.
Rich H.
Esse Quam Videri
Re: HEMI guys..... aluminum MP heads [Re: ZIPPY] #2673798
07/03/19 09:42 PM
07/03/19 09:42 PM
A727Tflite Offline
A727Tflite  Offline
The block issues were fixed once before - not too long ago. All the prints for the fix are in file cabinets down in Centerline.
That engineer retired not too long ago and recently he told me he received phones calls asking where the info was.
So maybe someone is actually looking to tool up again? One can only hope.
Re: HEMI guys..... aluminum MP heads [Re: A727Tflite] #2673880
07/04/19 08:11 AM
07/04/19 08:11 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Speaking of blocks, does anybody have some prints or CAD files? I have the front and rear bolt pattern drawings from the Chrysler books and various other little things, but does anybody have a file that I can use to machine a block from a billet?
Re: HEMI guys..... aluminum MP heads [Re: A727Tflite] #2674007
07/04/19 01:18 PM
07/04/19 01:18 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Well one can only hope.
Trans, from your discussion with D*****, it would seem
You might be talking about quality and engineering related problems with 2006 era water blocks,
Wheras I was attempting to talk about supply chain/purchasing and procurement issues with 2008-up
Dalton/World/formerly Royal oak boring (most recent NB Fowlerville) Siamese products.
In the case of the more current Siamese piece, it's a matter of getting people paid and kicked off.
the engineering related items were mostly ironed out. Compared to the water block, it might
Be low hanging fruit.....easier to deal with. That's the one I was referring to...
Truth be told, demand is high for both products...they're missing the boat....
I like D*****, However I have to remember when communicating with him he always considered
The World block to be vastly inferior, and something of a joke because of the amount of
engineering input from outside sources.
As you can imagine, I have opinions on that but will keep em to Myself.
Rich H.
Esse Quam Videri
Re: HEMI guys..... aluminum MP heads [Re: ZIPPY] #2674139
07/04/19 05:02 PM
07/04/19 05:02 PM
A727Tflite Offline
A727Tflite  Offline
Zippy - not sure who D****** is. My discussion on the fixes for the blocks was the actual engineer.
And yes I realize you were talking something else - I just piped in that the prints are there, fixed, someone has to step up just like you mentioned.
