Re: 10 second stroker recipe
[Re: fullmetaljacket]
#2673923
07/04/19 10:45 AM
07/04/19 10:45 AM
Posts: 361 mississippi
lostdog
mississippi
You could with a stroker, but it will have to have an arm and good heads and cam to bat. Yes, that’s right. I’m looking for the right info carb to oil pan and balancer to converter.
[Re: Dragula]
#2673935
07/04/19 11:19 AM
07/04/19 11:19 AM
Posts: 12,407 Taxes & Virus's R-US, NY
Dragula
Low tens requires a fairly stiff gear, converter, and cam. Not very street friendly. At 3650 lbs you need close to 700 hp corrected. It can be driven on the street but will just blow the tires off. 11.0 combo is probably a better street deal. Doug We went 10.73 the other week with 3.91 gears and mufflers and a .560 lift cam and IRON heads and 10.7:1.....Strokers don't seem to care much...Not sure what it weighs, probably 3500 with me in it. Wait till we get the new Indy fully ported 325's we just scored put on it! I prefer the 440Source 512 kits with the girdle and Indy heads. I know nothing about the Trick flows, but the Indy heads from the EZ1 on up to the 440-1's will hit 10's no problem. The more you spend here, the faster it goes...If I had it to do over on my race car, I would have probably gone to the B1 heads had I known how well those flowed. They seem to be one of the best "bracket" car heads out there and a step up from the Indy 440-1's. Intake, again we like an Indy 4150 single plane for street, and same thing in 4500 for race. Carbs, we like the cheap out of the box Proform 1050 or go all out and get a Thumper carb... I will go one step further since someone mentioned e-body's are heavy as a tank....which is not totally true by the way, But lets say you do want to go 10.0 the easy route..then switch from the 400/512 and do a 440/543 from 440Source...Torque is king in getting a car moving. Put a good set of heads on it as mentioned above and 10.7:1 compression, and you should be in the 9's on pump gas with a 4150 carb and an Indy single plane...
[Re: Dragula]
#2673964
07/04/19 12:08 PM
07/04/19 12:08 PM
Posts: 9,865 MI, usa
dvw
MI, usa
My street Challenger. Basically a slightly modified stocker. Small block, 4 speed, aluminum wheels, radiator, and intake, power steering, manual factory disc, headers, full exhaust. No cage or bar. 3580 w/o driver. Now as a race car yes you can lighten it up. But as a streeter it'll be 3700+ with driver easy. My previous race car made just over 700hp. It ran a best of 10.13@133@3475. No exhaust, loose converter, 4.10. A low 10 car needs at least a bar, exhaust for the street. At street weights that requires at least 700hp. Doug
[Re: dvw]
#2673972
07/04/19 12:18 PM
07/04/19 12:18 PM
Dragula
My street Challenger. Basically a slightly modified stocker. Small block, 4 speed, aluminum wheels, radiator, and intake, power steering, manual factory disc, headers, full exhaust. No cage or bar. 3580 w/o driver. Now as a race car yes you can lighten it up. But as a streeter it'll be 3700+ with driver easy. My previous race car made just over 700hp. It ran a best of 10.13@133@3475. No exhaust, loose converter, 4.10. A low 10 car needs at least a bar, exhaust for the street. At street weights that requires at least 700hp. Doug Any of the combo's I have mentioned above are right around 700hp depending on cam and heads...My current car is running 9.60's with one of these combo's and we have a 512 street car with Iron heads running 10.70's on its first outing already.....So, if it were me, I would take the easy road so the cam and gears are mild enough to be an enjoyable street car and go the 543 route....Now there is one concession on this type of build you should know about....You won't be using the internal oil pick up....For us, we would never go any other way, but others are sticklers for their favorite purple cam and stock oil pan pickup.....
[Re: Dragula]
#2673988
07/04/19 12:44 PM
07/04/19 12:44 PM
lostdog
mississippi
Low tens requires a fairly stiff gear, converter, and cam. Not very street friendly. At 3650 lbs you need close to 700 hp corrected. It can be driven on the street but will just blow the tires off. 11.0 combo is probably a better street deal. Doug We went 10.73 the other week with 3.91 gears and mufflers and a .560 lift cam and IRON heads and 10.7:1.....Strokers don't seem to care much...Not sure what it weighs, probably 3500 with me in it. Wait till we get the new Indy fully ported 325's we just scored put on it! I prefer the 440Source 512 kits with the girdle and Indy heads. I know nothing about the Trick flows, but the Indy heads from the EZ1 on up to the 440-1's will hit 10's no problem. The more you spend here, the faster it goes...If I had it to do over on my race car, I would have probably gone to the B1 heads had I known how well those flowed. They seem to be one of the best "bracket" car heads out there and a step up from the Indy 440-1's. Intake, again we like an Indy 4150 single plane for street, and same thing in 4500 for race. Carbs, we like the cheap out of the box Proform 1050 or go all out and get a Thumper carb... I will go one step further since someone mentioned e-body's are heavy as a tank....which is not totally true by the way, But lets say you do want to go 10.0 the easy route..then switch from the 400/512 and do a 440/543 from 440Source...Torque is king in getting a car moving. Put a good set of heads on it as mentioned above and 10.7:1 compression, and you should be in the 9's on pump gas with a 4150 carb and an Indy single plane... I like the idea of staying with the B engine bc that’s what I have but you’re right, the 440 stroker make make it easier to reach my target
[Re: Dragula]
#2673991
07/04/19 12:49 PM
07/04/19 12:49 PM
lostdog
mississippi
My street Challenger. Basically a slightly modified stocker. Small block, 4 speed, aluminum wheels, radiator, and intake, power steering, manual factory disc, headers, full exhaust. No cage or bar. 3580 w/o driver. Now as a race car yes you can lighten it up. But as a streeter it'll be 3700+ with driver easy. My previous race car made just over 700hp. It ran a best of 10.13@133@3475. No exhaust, loose converter, 4.10. A low 10 car needs at least a bar, exhaust for the street. At street weights that requires at least 700hp. Doug Any of the combo's I have mentioned above are right around 700hp depending on cam and heads...My current car is running 9.60's with one of these combo's and we have a 512 street car with Iron heads running 10.70's on its first outing already.....So, if it were me, I would take the easy road so the cam and gears are mild enough to be an enjoyable street car and go the 543 route....Now there is one concession on this type of build you should know about....You won't be using the internal oil pick up....For us, we would never go any other way, but others are sticklers for their favorite purple cam and stock oil pan pickup..... I have been doing some reading and wondering about if I should use external Oiler and also see where some recommend girdle on the mains. It’s never as easy as slap on some heads a cam and a crank kit ! Lol
[Re: dvw]
#2673992
07/04/19 12:50 PM
07/04/19 12:50 PM
lostdog
mississippi
My street Challenger. Basically a slightly modified stocker. Small block, 4 speed, aluminum wheels, radiator, and intake, power steering, manual factory disc, headers, full exhaust. No cage or bar. 3580 w/o driver. Now as a race car yes you can lighten it up. But as a streeter it'll be 3700+ with driver easy. My previous race car made just over 700hp. It ran a best of 10.13@133@3475. No exhaust, loose converter, 4.10. A low 10 car needs at least a bar, exhaust for the street. At street weights that requires at least 700hp. Doug Man that’s one badass small block !!
[Re: lostdog]
#2673994
07/04/19 12:52 PM
07/04/19 12:52 PM
Dragula
The girdle is a necessity at that power level, and so is a rev limiter set under 7k....
Well, on my race car we switched to a B engine for a lot of reasons. The main reason is it fits in our little A-body car a lot better than an RB....In an E-body, there is a ton of room. Other than that, we have not seen any other real advantage to them....If you have a good one, build what you have. They can easily make +700hp....Ours went 6.16 at 111.5mph last weekend in the heat of the day....There is more in it as our carb is still lean thru the whole rpm range yet. So we will see.
Looking to do somthing a lot different for next year though......
[Re: lostdog]
#2674016
07/04/19 01:27 PM
07/04/19 01:27 PM
Posts: 4,210 New York
polyspheric
New York
Nitrous substitutes the danger of breakage due to accident ("did I hook up the fuel solenoid?", "how many degrees retard per HP added?") for the danger of breakage due to the higher RPM of an NA engine with the same power. Nitrous also does not screw up your idle quality, gas mileage, and traffic manners.
Boffin Emeritus
[Re: lostdog]
#2674308
07/05/19 06:20 AM
07/05/19 06:20 AM
dvw
MI, usa
My street Challenger. Basically a slightly modified stocker. Small block, 4 speed, aluminum wheels, radiator, and intake, power steering, manual factory disc, headers, full exhaust. No cage or bar. 3580 w/o driver. Now as a race car yes you can lighten it up. But as a streeter it'll be 3700+ with driver easy. My previous race car made just over 700hp. It ran a best of 10.13@133@3475. No exhaust, loose converter, 4.10. A low 10 car needs at least a bar, exhaust for the street. At street weights that requires at least 700hp. Doug Man that’s one badass small block !! I wasnt clear. The Challengers specs were in referance of E body weights. The old race car was a 63 Dodge 498 with unported-1s and a factory cross ram. Doug
[Re: Twostick]
#2674355
07/05/19 10:02 AM
07/05/19 10:02 AM
lostdog
mississippi
Is boost an option?
512, good heads with a mild cam should hit that goal by accident.
Kevin my original plan was to use a blower but i think because of ease my power adder of choice would be nitrous
[Re: MR_P_BODY]
#2674408
07/05/19 12:21 PM
07/05/19 12:21 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
In the OP’s first post: I’m looking to be in the mid-low 10’s on motor Ron’s 63 is a great running combo, in a sweet looking ride for sure. But...... that’s not “low” 10’s........ and it’s probably a few grand difference in $$$ too.
[Re: fast68plymouth]
#2674410
07/05/19 12:26 PM
07/05/19 12:26 PM
Posts: 4,690 On the parachute mount
n20mstr
In the OP’s first post: I’m looking to be in the mid-low 10’s on motor Ron’s 63 is a great running combo, in a sweet looking ride for sure. But...... that’s not “low” 10’s........ and it’s probably a few grand difference in $$$ too. I have personally witnessed Ron drive that car into Cecil county...he was behind me in the line going in. Any way....he said his car was 3700? withought hin in it.... Put that driveline in a 3000lb A body...there you go LOW streetable Tens, maybe even a high 9 ! OK I went back, the OP has a 73 barracuda. Copy Rons combo and make sure the car weights 3100-3400...
....BAD A$$ STREET CAR.....
