Been wanting to go EFI, found a deal I could not pass up, always wanted this set up but the price said NO WAY until this came up on Moparts, took one intake apart & started grinding for Max wedge ports, got a little done but the heat was to much, I will just have to pace myself & get done what I can,may take awhile LOL. I am SO exited to get this for the Charger
Looks like they designed it to be made into MW size.
Yes I called Hilborn before I bought it & they said the max wedge was the same casting as the 440 port. The shadowing in the picture makes it look like I did not follow the contour of the port, but I did.
Having said that, what do you expect to get by way of results (other than the known EFI benefits)?
I did a lot of EFI Individual runner intakes on Harley's back before I got sick, IR set ups & longer runner will idle MUCH better with a large cam, much better drivability, low & midrange torque is much better, I have posted this dyno sheet before , this is my old 2005 Dyna FXDWG, 94.2 cid EFI, the blue lines are with approx 8in long runner, the red lines are 24in IIRC, nothing else was change, my Charger is a street car , it is already a blast to drive , this should step it up a notch or 2, plus it will look awesome sticking out of the hood.
I agree, but AFAIK the only stack injection nearly large enough is the Crower for BBC, which has 2.90" butterflies.
Depends on how much power you want, the set up I have flows way more than I need for the power level I am at now, 2.9 butterflies are in the 1000 + hp, I am in the low 600, street car, overdrive A/C . Hilborn does make the 3" bore, My butterflies are 2.4375,the runners are 2.5 id, do the math my intake valve is 2.14, the id of the intake seat is 1.94
The sound of my 440" Mopar all Detroit Iron engine except for the Aluminium IR Intake ....! .040" Over HP 440 Block Factory Steel Crank Pro Ported 2.08/1.74 452 Motor home heads .528" MP Solid Old Gold Crane 1.6 Roller Rockers SP/JE pistons & Rings 10:7:1 Manley Rods
On the video it breaks traction @ 55 mph <You can hear the rev Limiter soft cut the ign @ 6,300 RPM, ahh the joys of crisp digital EFI Tuning>
glad you got such a deal ! as a fellow charger owner, and having the same health problem you do, i follow your exploits. that is gonna look fantastic sticking out of your hood !
