Trick Flow 270's #2671513
06/29/19 11:41 AM
06/29/19 11:41 AM
PORT ALBERNI , BC., CANADA
superwrench Offline OP
I'm debating on whether to order the TrickFlow 240's or the 270's with the Max wedge intake port. I have a set of mild CNC'd Edelbrocks on my 496 at the moment and they seem to do fine, but as always...there's always room for improvement..Right??!! So...if I'm on the right page here, I'm presuming that I would no longer be using the stock type intake gasket but would be going to a valley plate and paper gaskets.....and would it make any sense to take my Victor and port match it to the heads, or is there another manifold that I can still use and retain a 4150 style carb. I don't want to use a dominator if possible as I do some street driving too.
Re: Trick Flow 270's [Re: superwrench] #2671522
06/29/19 11:53 AM
06/29/19 11:53 AM
I have use the Indy brand M.W. size intakes with both 4150 and 4500 type carbs, if your running a high deck motor the 440-2 intake is the part # for the 4150 type carbs, 440-3 for the Dominator flange carbs up 400-2 and 400-3 for the low deck motors.
BTW I have used and liked the 4500 type carbs on the street after some tuning on them, they work great work up scope
in todays world of custom built carbs and the increased competition to Holley there are many good choices on a new bigger carb, more airflow and fuel= More power in every BB Mopar I've tuned and drivendevil
Re: Trick Flow 270's [Re: Cab_Burge] #2671573
06/29/19 01:23 PM
06/29/19 01:23 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Well my 505 with OOTB 270's made 713 hp 707 torque with a 4150 950 cfm carb and a Dwayne Porter roller cam. Mopar 337 intake (no valley pan) - needed small adapters on the ends to make fit.
Not in the car yet but it will be street driven.
Re: Trick Flow 270's [Re: superwrench] #2671613
06/29/19 03:44 PM
06/29/19 03:44 PM
AndyF Online content
AndyF  Online Content
There are not a lot of choices for MW ports with a 4150 carb. The MP 337 is a good intake but hard to find. The Indy 440-2 is taller and works okay in cast form but it isn't great. Some port matching is usually required to get it to work. If you're shooting for less than 700 hp then I'd go with the 240 heads. If you want to make more than 700 hp then the 270 heads will help you get there. If you want to keep your Victor intake then you need to keep the 240 heads.
Re: Trick Flow 270's [Re: markz528] #2671615
06/29/19 03:47 PM
06/29/19 03:47 PM
We had a pump gas 505 on the dyno recently that made almost exactly the same power. It has TF 270 heads with a port matched Indy 440-2 intake and a Holley Sniper. That engine had a Comp street roller cam in it and 2 inch dyno headers. Nice strong engine that is going into a 1969 RoadRunner. Should be a fierce combo on the street.
Re: Trick Flow 270's [Re: AndyF] #2671752
06/29/19 11:04 PM
06/29/19 11:04 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
The 270s will / should simply make more power . If you have enough motor .
I have been running my 270s for just over 12 months . Daily driver monthly bracket racing .
I swapped from Stealth cnc to the 270 , same Super Victor intake . Picked up a hair over 0.25 seconds and around 2-3 mph .
More than happy
Went 10.28 last weekend @ 3775lbs
All with a solid flat tappet cam
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Trick Flow 270's [Re: AndyF] #2673574
07/03/19 12:42 PM
07/03/19 12:42 PM
Thanks Andy. I'm starting to think the 240's would be sufficient too. What's your take on Bullet Cams?? Solid flat tappet in the .600 lift range.
Re: Trick Flow 270's [Re: markz528] #2715010
11/12/19 03:50 AM
11/12/19 03:50 AM
Indiana
64nss330 Offline
64nss330  Offline
Indiana
What's your basic cam specs?
Re: Trick Flow 270's [Re: 64nss330] #2715280
11/12/19 10:03 PM
11/12/19 10:03 PM
BigFish69 Offline
BigFish69  Offline
Why couldn't you port the victor intake for the 270 heads?
