Trick Flow 270's
#2671513
06/29/19 11:41 AM
06/29/19 11:41 AM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
I'm debating on whether to order the TrickFlow 240's or the 270's with the Max wedge intake port. I have a set of mild CNC'd Edelbrocks on my 496 at the moment and they seem to do fine, but as always...there's always room for improvement..Right??!! So...if I'm on the right page here, I'm presuming that I would no longer be using the stock type intake gasket but would be going to a valley plate and paper gaskets.....and would it make any sense to take my Victor and port match it to the heads, or is there another manifold that I can still use and retain a 4150 style carb. I don't want to use a dominator if possible as I do some street driving too.
Re: Trick Flow 270's
[Re: Cab_Burge]
#2671573
06/29/19 01:23 PM
06/29/19 01:23 PM
Posts: 4,291 Morrow, OH
markz528
Morrow, OH
Well my 505 with OOTB 270's made 713 hp 707 torque with a 4150 950 cfm carb and a Dwayne Porter roller cam. Mopar 337 intake (no valley pan) - needed small adapters on the ends to make fit.
Not in the car yet but it will be street driven.
[Re: markz528]
#2671615
06/29/19 03:47 PM
06/29/19 03:47 PM
Posts: 31,082 Oregon
AndyF
Not in the car yet but it will be street driven. We had a pump gas 505 on the dyno recently that made almost exactly the same power. It has TF 270 heads with a port matched Indy 440-2 intake and a Holley Sniper. That engine had a Comp street roller cam in it and 2 inch dyno headers. Nice strong engine that is going into a 1969 RoadRunner. Should be a fierce combo on the street.
[Re: AndyF]
#2671752
06/29/19 11:04 PM
06/29/19 11:04 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
The 270s will / should simply make more power . If you have enough motor . I have been running my 270s for just over 12 months . Daily driver monthly bracket racing . I swapped from Stealth cnc to the 270 , same Super Victor intake . Picked up a hair over 0.25 seconds and around 2-3 mph . More than happy Went 10.28 last weekend @ 3775lbs All with a solid flat tappet cam
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: markz528]
#2715010
11/12/19 03:50 AM
11/12/19 03:50 AM
Posts: 19 Indiana
64nss330
Indiana
What's your basic cam specs? Well my 505 with OOTB 270's made 713 hp 707 torque with a 4150 950 cfm carb and a Dwayne Porter roller cam. Mopar 337 intake (no valley pan) - needed small adapters on the ends to make fit.
