Re: LD340
[Re: 68goldfish]
#2670929
06/27/19 10:44 PM
06/27/19 10:44 PM
RapidRobert
Not sure how much of a hood clearance issue you have but on a side note the Holley street dominator is very low profile aluminum intake & is a single plane but reportedly works very well at low(er) RPM's & is a VG general purpose intake & it is fairly cheap used.
Re: LD340
[Re: dogdays]
#2676329
07/10/19 04:46 PM
07/10/19 04:46 PM
Posts: 28,600 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I call BS on the "same as a stock intake". They run more close to the Performer RPM as told by dozens of posts here over the last 14 years. R. The one I had was slightly taller than a 340 cast iron one It fit under the hood
Re: LD340
[Re: GODSCOUNTRY340]
#2676340
07/10/19 05:07 PM
07/10/19 05:07 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I ran an M1 single plane under the hood of my 68 Barracuda with a factory air cleaner no problem.
I use my I phone to check hood clearance. I turn the light on in video mode, set it up and close the hood(gently of course). The result is a good video of how much room you have left.
68 Barracuda Formula S 340
Re: LD340
[Re: roadrunninMark]
#2676412
07/10/19 09:47 PM
07/10/19 09:47 PM
Posts: 1,149 NW New Jersey
RSI700VIPER
NW New Jersey
The LD 340 was the manifold of choice for a 340/360 for 4 decades.
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5 1969 Daytona Charger 440 4-Speed, Dana, EV2 1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7 1970 340 Six Pack Callenger T/A 4-speed T8 Tan 1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth 1969 Talladega Torino, 428CJ 1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: LD340
[Re: RSI700VIPER]
#2676501
07/11/19 08:44 AM
07/11/19 08:44 AM
Posts: 6,267 nowhere
Sniper
nowhere
The LD 340 was the manifold of choice for a 340/360 for 4 decades. the key word in that statement is was. Time has passed it by.
Re: LD340
[Re: 68goldfish]
#2676514
07/11/19 09:13 AM
07/11/19 09:13 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Hey, All! Been lurking on here for years. One question. Will this combo fit under the hood. My 68' A Body Barracuda. 340 Block. Stock Carter Carb. Stock Air cleaner. LD340 Intake with paper gasket. Mighty mounts holding it in? Yes? Should fit but will be super close. I'm running one with a Holley 3310 (which I believe is taller) and using an air cleaner with a drop base (7/8" drop IIRC). ('67 Barracuda) Get some 'clay' or lightly ball up some aluminum foil on the air cleaner stud and gently close the hood. As was clarified before, the LD340 is not an aluminum copy of the stock intake. Some version came with Chrysler part numbers - and for class racing - they were legal - and by following the guidelines in the bulletins they worked well. The big runners lose velocity at low rpm relative to stock, or LD4B, and most likely one reason why the new "RPM" are better for street and building torque earlier at WOT.
Re: LD340
[Re: Mattax]
#2676602
07/11/19 03:50 PM
07/11/19 03:50 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
LD340 way above the stock intake. Stock alum replacement would be like the Performer. I ran 11.30's with an LD340 on a relatively mild 360 in a Duster.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
Re: LD340
[Re: 68goldfish]
#2676606
07/11/19 04:01 PM
07/11/19 04:01 PM
Posts: 8,670 Buford, GA
I_bleed_MOPAR
Buford, GA
Late to the party but anyway.... I switched from a stock intake to an LD340 on the '68 340 I had in my '65 Valiant and had no issues. Not up on the difference in measurements on the 2 but I would hazard a guess that the 'cuda has a tad more room. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
Re: LD340
[Re: RapidRobert]
#2676813
07/12/19 01:07 PM
07/12/19 01:07 PM
340SIX
Not sure how much of a hood clearance issue you have but on a side note the Holley street dominator is very low profile aluminum intake & is a single plane but reportedly works very well at low(er) RPM's & is a VG general purpose intake & it is fairly cheap used. I pulled the TQ off my 1972 340 and intake and put a Street Dominator and the car was way better streetwise but think it suffered top end, till I put a Holley #4776 650DP I should have used an LD340 and cut the center down like they said t do back then. But the Holley was $75.00 new from a guy who went with a Strip-Dom with Large Cam and made his car cool but slow
