LD340 #2670841
06/27/19 06:45 PM
06/27/19 06:45 PM
Worcester, Mass
68goldfish Offline OP
Worcester, Mass
Hey, All!
Been lurking on here for years. One question. Will this combo fit under the hood. My 68' A Body Barracuda. 340 Block. Stock Carter Carb. Stock Air cleaner. LD340 Intake with paper gasket. Mighty mounts holding it in? Yes?
Re: LD340 [Re: 68goldfish] #2670864
06/27/19 07:34 PM
06/27/19 07:34 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Not sure what mighty mounts are but otherwise shouldn't be a problem. The LD is basically an aluminum version of the factory intake beer
Re: LD340 [Re: TJP] #2670871
06/27/19 08:06 PM
06/27/19 08:06 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
Without a choke well and a boss to mount an A/C compressor.
Re: LD340 [Re: 68goldfish] #2670929
06/27/19 10:44 PM
06/27/19 10:44 PM
Happy Birthday RapidRobert  Offline
Not sure how much of a hood clearance issue you have but on a side note the Holley street dominator is very low profile aluminum intake & is a single plane but reportedly works very well at low(er) RPM's & is a VG general purpose intake & it is fairly cheap used.
Re: LD340 [Re: RapidRobert] #2670990
06/28/19 07:29 AM
06/28/19 07:29 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
LD340 as mentioned is the stock height so will fit under any stock hood.
Re: LD340 [Re: Morty426] #2671234
06/28/19 05:16 PM
06/28/19 05:16 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
The LD 340 is approximately a .5" higher than a stock manifold.
https://www.forabodiesonly.com/mopar/threads/ld-340-height.32120/
Re: LD340 [Re: cruzin] #2675414
07/08/19 01:25 AM
07/08/19 01:25 AM
dogdays Offline
dogdays  Offline
I call BS on the "same as a stock intake".
They run more close to the Performer RPM as told by dozens of posts here over the last 14 years.
R.
Re: LD340 [Re: dogdays] #2675423
07/08/19 05:06 AM
07/08/19 05:06 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
An intake manifold ahead of its time. Does it all- low end-mid and top end.
Keep old mopars alive.
Re: LD340 [Re: dogdays] #2676329
07/10/19 04:46 PM
07/10/19 04:46 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
R.
The one I had was slightly taller than a 340 cast iron one It fit under the hood
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: LD340 [Re: 340SIX] #2676336
07/10/19 04:59 PM
07/10/19 04:59 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Here's an LD340 in a '72 demon and it fits under stock hood.
Re: LD340 [Re: GODSCOUNTRY340] #2676340
07/10/19 05:07 PM
07/10/19 05:07 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I ran an M1 single plane under the hood of my 68 Barracuda with a factory air cleaner no problem.
I use my I phone to check hood clearance. I turn the light on in video mode, set it up and close the hood(gently of course). The result is a good video of how much room you have left.
68 Barracuda Formula S 340
87 "Chrysler" Conquest
Re: LD340 [Re: Bad340fish] #2676343
07/10/19 05:13 PM
07/10/19 05:13 PM
GA
roadrunninMark Offline
GA
Here is a pretty good list of intake info from forabodiesonly. https://www.forabodiesonly.com/mopar/threads/getting-the-intake-on-intake-manifolds.283550/
Re: LD340 [Re: roadrunninMark] #2676412
07/10/19 09:47 PM
07/10/19 09:47 PM
NW New Jersey
RSI700VIPER Offline
RSI700VIPER  Offline
NW New Jersey
The LD 340 was the manifold of choice for a 340/360 for 4 decades.
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: LD340 [Re: RSI700VIPER] #2676501
07/11/19 08:44 AM
07/11/19 08:44 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
the key word in that statement is was. Time has passed it by.
Re: LD340 [Re: 68goldfish] #2676514
07/11/19 09:13 AM
07/11/19 09:13 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Originally Posted by 68goldfish
Hey, All!
Should fit but will be super close. I'm running one with a Holley 3310 (which I believe is taller) and using an air cleaner with a drop base (7/8" drop IIRC). ('67 Barracuda)
Get some 'clay' or lightly ball up some aluminum foil on the air cleaner stud and gently close the hood.
As was clarified before, the LD340 is not an aluminum copy of the stock intake.
Some version came with Chrysler part numbers - and for class racing - they were legal - and by following the guidelines in the bulletins they worked well.
The big runners lose velocity at low rpm relative to stock, or LD4B, and most likely one reason why the new "RPM" are better for street and building torque earlier at WOT.
Re: LD340 [Re: Mattax] #2676602
07/11/19 03:50 PM
07/11/19 03:50 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
LD340 way above the stock intake. Stock alum replacement would be like the Performer. I ran 11.30's with an LD340 on a relatively mild 360 in a Duster.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: LD340 [Re: 68goldfish] #2676606
07/11/19 04:01 PM
07/11/19 04:01 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Late to the party but anyway.... wink
I switched from a stock intake to an LD340 on the '68 340 I had in my '65 Valiant and had no issues. Not up on the difference in measurements on the 2 but I would hazard a guess that the 'cuda has a tad more room. up
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: LD340 [Re: I_bleed_MOPAR] #2676761
07/12/19 10:12 AM
07/12/19 10:12 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Same height as the 68-71 340
Abe Lincoln
Re: LD340 [Re: RapidRobert] #2676813
07/12/19 01:07 PM
07/12/19 01:07 PM
340SIX Offline
340SIX  Offline
I pulled the TQ off my 1972 340 and intake and put a Street Dominator and the car was way better streetwise but think it suffered top end, till I put a Holley #4776 650DP
I should have used an LD340 and cut the center down like they said t do back then. But the Holley was $75.00 new from a guy who went with a Strip-Dom with Large Cam and made his car cool but slow
