Question on best deal for getting a new 2006 key programmed #2670332
06/26/19 06:11 PM
06/26/19 06:11 PM
Ball Ground, Georgia
Dixie Offline OP
Dixie  Offline OP
Hey guys,
My daughter has a 2006 PT Cruiser and the plastic part of the key has broken. It still works, but is in two pieces. The dealer wants $150+ for a newly reprogrammed key, while ebay has keys for $6 that need programming. What's the most cost effective way of getting a new key for this old beater?
Thanks!!
Randy
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: Question on best deal for getting a new 2006 key programmed [Re: Dixie] #2670341
06/26/19 06:42 PM
06/26/19 06:42 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
If its just the shell.
Aftermkt has them. No programing needed.
If you have 2 keys .you dont need the dealer to.program it
Me personally im not a fan of the aftermarket key fobs. Had bad luck with longevity of a few.
Re: Question on best deal for getting a new 2006 key programmed [Re: Dixie] #2670355
06/26/19 07:05 PM
06/26/19 07:05 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
If you can do without the security of a chip key, I have a cheap solution.
The gray key is a proximity key, which means that it only needs to be close enough to the transponder by the switch to communicate. So, go to your local hardware store and have them cut you as many of the cheap black (non chip) keys to fit the switch as you want. Then pull the lower cover off the column and tape or glue the original gray key in there so that the transponder communicates with that original key. Re-install the lower cover and you can use the cheap (black) key that you cut to fit.
Have done this many times.
Master, again and still
Re: Question on best deal for getting a new 2006 key programmed [Re: Dixie] #2670522
06/27/19 02:47 AM
06/27/19 02:47 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Question on best deal for getting a new 2006 key programmed [Re: John_Kunkel] #2670663
06/27/19 01:08 PM
06/27/19 01:08 PM
Dixie Offline OP
Dixie  Offline OP
Thanks for the info guys. She only has one key for it, so that makes it a little more tricky.
Re: Question on best deal for getting a new 2006 key programmed [Re: Dixie] #2670716
06/27/19 02:04 PM
06/27/19 02:04 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Then you have only 2 choices. replace the shell if the key fob itself works
Go see your local Mopar dealer.
Regardless of what anyone tells you. You can NOT program a key in the field if you only have the one
Re: Question on best deal for getting a new 2006 key programmed [Re: gtx6970] #2670717
06/27/19 02:05 PM
06/27/19 02:05 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Key look like so ?
if so , I dont think the aftermkt services these as just a shell to replace the plastic.
Pretty sure its full key only.
I'll tell you ahead of time some dealers may not program these aftermkt keys due to the issues they come with
Re: Question on best deal for getting a new 2006 key programmed [Re: gtx6970] #2670740
06/27/19 02:49 PM
06/27/19 02:49 PM
Dixie Offline OP
Dixie  Offline OP
Yep, that's what she looks like.
Re: Question on best deal for getting a new 2006 key programmed [Re: gtx6970] #2670746
06/27/19 02:58 PM
06/27/19 02:58 PM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
Originally Posted by gtx6970
[quote=Dixie][quote]
Not 100% sure about 06 and newer but on 05 and older you can.. The procedure is in the owners manual, I did it once when I lost one of my keys to my Rumblebee..
Re: Question on best deal for getting a new 2006 key programmed [Re: rumblebee4232] #2670760
06/27/19 03:48 PM
06/27/19 03:48 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Originally Posted by rumblebee4232
[quote=gtx6970][quote=Dixie]
Quote
Would like to know where or how
I had to get my local dealer do the one for my daughters 04 Neon.
Again we only had the 1 key.
Re: Question on best deal for getting a new 2006 key programmed [Re: gtx6970] #2670780
06/27/19 04:40 PM
06/27/19 04:40 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
The local locksmith in our one-horse town of 3200 people can furnish programmed key fobs. I'm guessing someone in your area, other than the dealer, could also.
Re: Question on best deal for getting a new 2006 key programmed [Re: 6PakBee] #2670815
06/27/19 06:08 PM
06/27/19 06:08 PM
Dixie Offline OP
Dixie  Offline OP
Great idea! Thanks, I'll check around.
Re: Question on best deal for getting a new 2006 key programmed [Re: Dixie] #2670827
06/27/19 06:26 PM
06/27/19 06:26 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
The CarrotVan OEM fob ....... where it hooks onto a key ring .... that little tab always breaks. The pair I got off eBay some years back SPECIFICALLY guarantees that THAT will never break. The pair was like 8$ delivered. You need to get the key cut though
Re: Question on best deal for getting a new 2006 key programmed [Re: gtx6970] #2670830
06/27/19 06:28 PM
06/27/19 06:28 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
Key look like so ?
getX .... issues ? ....
Re: Question on best deal for getting a new 2006 key programmed [Re: dOrk !] #2670948
06/27/19 11:28 PM
06/27/19 11:28 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Key look like so ?
Supposedly sometime the keys will "lose" the programming.
I've had multiple Ebay aftermarket keys programmed at a locksmith and haven't had a problem so far.
The Father in Law has bought some key programming box off ebay and as soon as he brings it over we'll be programming the ebay keys for my 2007 300 SRT8 (which only came with one key).
He's used it on his and a few other Chrysler vehicles with no problem so far.
Re: Question on best deal for getting a new 2006 key programmed [Re: dOrk !] #2670951
06/27/19 11:37 PM
06/27/19 11:37 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Key look like so ?
Mainly had to be right on top of the car for the fob to unlock the doors and way to short battery life IMO
We had customers come back in 3 or 4 months with key issues. After about half dozen come backs over maybe 12-18 month period we refused to cut or program aftermkt keys altogether at the dealership I worked at
Re: Question on best deal for getting a new 2006 key programmed [Re: gtx6970] #2680246
07/22/19 08:56 PM
07/22/19 08:56 PM
Stinnett, Tx
Stinnett, Tx
Quote
Re: Question on best deal for getting a new 2006 key programmed [Re: rumblebee4232] #2680861
07/24/19 10:38 AM
07/24/19 10:38 AM
Halifax, VA.
moparjack44 Offline
moparjack44  Offline
Halifax, VA.
I've been suffering with my 05 Durango for a year. Key works, fob not so much. I'm afraid to lock the doors. Hell, closest MoPar dealer is 30 miles away and they are all butt holes.
K.I.S.S.
Re: Question on best deal for getting a new 2006 key programmed [Re: Dixie] #2680866
07/24/19 10:49 AM
07/24/19 10:49 AM
GMP440 Offline
GMP440  Offline
Has anyone tried one of these? This is a key and a programming device.
https://www.youtube.com/watch?v=-ZijvyGWroc
Re: Question on best deal for getting a new 2006 key programmed [Re: GMP440] #2680888
07/24/19 11:58 AM
07/24/19 11:58 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Dorman sells those also for about $85. But no one sells them for Mopars.
