Re: Question on best deal for getting a new 2006 key programmed
[Re: Dixie]
#2670355
06/26/19 07:05 PM
06/26/19 07:05 PM
Posts: 11,890 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
If you can do without the security of a chip key, I have a cheap solution.
The gray key is a proximity key, which means that it only needs to be close enough to the transponder by the switch to communicate. So, go to your local hardware store and have them cut you as many of the cheap black (non chip) keys to fit the switch as you want. Then pull the lower cover off the column and tape or glue the original gray key in there so that the transponder communicates with that original key. Re-install the lower cover and you can use the cheap (black) key that you cut to fit.
Have done this many times.
Master, again and still
[Re: Dixie]
#2670716
06/27/19 02:04 PM
06/27/19 02:04 PM
Posts: 21,345 It's a dry heat
gtx6970
It's a dry heat
Thanks for the info guys. She only has one key for it, so that makes it a little more tricky. Then you have only 2 choices. replace the shell if the key fob itself works Go see your local Mopar dealer. Regardless of what anyone tells you. You can NOT program a key in the field if you only have the one
[Re: gtx6970]
#2670717
06/27/19 02:05 PM
06/27/19 02:05 PM
gtx6970
It's a dry heat
Key look like so ? if so , I dont think the aftermkt services these as just a shell to replace the plastic. Pretty sure its full key only. I'll tell you ahead of time some dealers may not program these aftermkt keys due to the issues they come with
[Re: gtx6970]
#2670746
06/27/19 02:58 PM
06/27/19 02:58 PM
Posts: 198 Stinnett, Tx
rumblebee4232
Stinnett, Tx
[quote=Dixie][quote]
Go see your local Mopar dealer. Regardless of what anyone tells you. You can NOT program a key in the field if you only have the one Not 100% sure about 06 and newer but on 05 and older you can.. The procedure is in the owners manual, I did it once when I lost one of my keys to my Rumblebee..
[Re: rumblebee4232]
#2670760
06/27/19 03:48 PM
06/27/19 03:48 PM
gtx6970
It's a dry heat
[quote=gtx6970][quote=Dixie]
Not 100% sure about 06 and newer but on 05 and older you can.. The procedure is in the owners manual, I did it once when I lost one of my keys to my Rumblebee.. Would like to know where or how I had to get my local dealer do the one for my daughters 04 Neon. Again we only had the 1 key.
[Re: gtx6970]
#2670780
06/27/19 04:40 PM
06/27/19 04:40 PM
Posts: 10,666 North Dakota
6PakBee
North Dakota
The local locksmith in our one-horse town of 3200 people can furnish programmed key fobs. I'm guessing someone in your area, other than the dealer, could also.
[Re: 6PakBee]
#2670815
06/27/19 06:08 PM
06/27/19 06:08 PM
Posts: 2,336 Ball Ground, Georgia
Dixie
The local locksmith in our one-horse town of 3200 people can furnish programmed key fobs. I'm guessing someone in your area, other than the dealer, could also. Great idea! Thanks, I'll check around.
[Re: gtx6970]
#2670830
06/27/19 06:28 PM
06/27/19 06:28 PM
Posts: 30,248 Florida STAYcation
dIc dOc Deity !
The village idiot's idiot
Florida STAYcation
getX .... issues ? ....
[Re: dIc dOc Deity !]
#2670948
06/27/19 11:28 PM
06/27/19 11:28 PM
Posts: 10,115 A Red State
SNK-EYZ
A Red State
getX .... issues ? .... Supposedly sometime the keys will "lose" the programming. I've had multiple Ebay aftermarket keys programmed at a locksmith and haven't had a problem so far. The Father in Law has bought some key programming box off ebay and as soon as he brings it over we'll be programming the ebay keys for my 2007 300 SRT8 (which only came with one key). He's used it on his and a few other Chrysler vehicles with no problem so far.
#2670951
06/27/19 11:37 PM
06/27/19 11:37 PM
gtx6970
It's a dry heat
getX .... issues ? .... Mainly had to be right on top of the car for the fob to unlock the doors and way to short battery life IMO We had customers come back in 3 or 4 months with key issues. After about half dozen come backs over maybe 12-18 month period we refused to cut or program aftermkt keys altogether at the dealership I worked at
[Re: gtx6970]
#2680246
07/22/19 08:56 PM
07/22/19 08:56 PM
rumblebee4232
Stinnett, Tx
[Re: rumblebee4232]
#2680861
07/24/19 10:38 AM
07/24/19 10:38 AM
Posts: 211 Halifax, VA.
moparjack44
Halifax, VA.
I've been suffering with my 05 Durango for a year. Key works, fob not so much. I'm afraid to lock the doors. Hell, closest MoPar dealer is 30 miles away and they are all butt holes.
K.I.S.S.
