Any good stand alone controller ? #2669493
06/24/19 07:01 PM
06/24/19 07:01 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
Any easy harness and computer set up that will run with all the factory sensors on a take out early 5.7 engine?
Re: Any good stand alone controller ? [Re: HotRodDave] #2669575
06/24/19 10:13 PM
06/24/19 10:13 PM
cbusters Offline
cbusters  Offline
I have the MSD Hemi 6 on mine.
Re: Any good stand alone controller ? [Re: cbusters] #2669664
06/25/19 07:34 AM
06/25/19 07:34 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Look at the EFI Source Gold Box. They have a nice plug and play harness.
If I were to go this route I would use an MS3Pro Evo or Ultimate and repin the EFI source harness to work. That is mainly because I have had good luck and service with DiyAutotune with my current EFI small block.
68 Barracuda Formula S 340
Re: Any good stand alone controller ? [Re: Bad340fish] #2669780
06/25/19 12:57 PM
06/25/19 12:57 PM
Kalispell Mt.
Kalispell Mt.
The hemi 6 is only for ignition correct?
I been looking at the MS3Pro evo ultimate and now I am more confused than a termite in a wooden yo yo... I don't see a kit that says it if for the gen III hemi anywhere?
Re: Any good stand alone controller ? [Re: Bad340fish] #2669888
06/25/19 06:54 PM
06/25/19 06:54 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I would suggest an MS, but it does not support drive-by-wire, I took the original post as not wanting to change anything but just drop in the stock engine and go.
The MS stuff isn't the most intuitive, however.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Any good stand alone controller ? [Re: HotRodDave] #2670009
06/25/19 11:53 PM
06/25/19 11:53 PM
Salem
Grizzly Online tonguue
Moparts Proctologist
Grizzly  Online Tonguue
Salem
As expected, there is no answer to this question.
Dave, I followed it for awhile and decided a few years ago:
it's a lost cause. twocents
I can't believe it still needs to be said, but, the Daimler computer is un-crackable, and no BS "change-your-shift-points" sct, diablo or superchips amateur junk is ever going to cut the mustard. Some have claimed to have done it, and those that fell for it got their vehicle locked up and had to pay a dealership to fix the "tuner" mess. "Hemifever" comes to mind, I believe he is living under a new identity, lol.
All I can offer is to go to a Blunder Motors based tuning platform and adapt it to run a Gen 3. It's a last resort, and has been done. To make matters worse, from what I've read lately, even they are going forward with locking up their new vehicles either this year or next.
Or, hope for 350 cfm heads that don't leak water for $2000 a pair for LA/Magnum's. shruggy
Mo' Farts
Moderated by "tbagger".
Re: Any good stand alone controller ? [Re: HotRodDave] #2670086
06/26/19 08:54 AM
06/26/19 08:54 AM
Columbus, OH
65Dodge440 Offline
65Dodge440  Offline
Columbus, OH
Hey HotRodDave,
Isn't this designed for complete take outs and crate engines?
https://www.manciniracing.com/mo5crheinkit.html
A friend of mine used the 6.4 kit to put a 6.4 in a old Ford F100 and he said it couldn't have been simpler. I would go this route but my engine is far from stock so I got an MS3. Hopefully Mike helps me tune it when its finished. laugh
Re: Any good stand alone controller ? [Re: 65Dodge440] #2670181
06/26/19 12:40 PM
06/26/19 12:40 PM
IL
furious70 Offline
furious70  Offline
IL
Originally Posted by 65Dodge440
Hey HotRodDave,
I don't believe the crate stuff uses the early sensors and such he's asking about. But yes, for later/crate stuff, this is definitely a write a check and install it option for a stock(ish) engine. A modified or boosted engine needs something different.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Any good stand alone controller ? [Re: furious70] #2670251
06/26/19 02:45 PM
06/26/19 02:45 PM
Kalispell Mt.
Kalispell Mt.
Now were getting somewhere, what sensors am I sposed to use with that mopar kit? And why does it look like there re two controllers?
Re: Any good stand alone controller ? [Re: HotRodDave] #2670269
06/26/19 03:32 PM
06/26/19 03:32 PM
Columbus, OH
65Dodge440 Offline
65Dodge440  Offline
Columbus, OH
I didn't realize the MP kits are for the newer VVT engines. I wonder if you switched to new sensors if it would work? Or if the VVT and too many other things are different.
What about this: https://swapspecialties.com/product/hemi-standalone-harness/
Re: Any good stand alone controller ? [Re: HotRodDave] #2670490
06/26/19 11:11 PM
06/26/19 11:11 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I believe it's a hair more complicated than just swapping sensors, I'm fairly certain the crank trigger wheel would need to be swapped. Which requires the crank to come out of the block.
The "G3 Hemi Swap" facebook group may have some folks that have gone through that.
2020 RAM 1500
Re: Any good stand alone controller ? [Re: GoodysGotaCuda] #2670540
06/27/19 07:25 AM
06/27/19 07:25 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
What is your goal? Do you just want to make a stock hemi run in a non OE application or do you want full tuning ability?
Re: Any good stand alone controller ? [Re: Bad340fish] #2670593
06/27/19 10:17 AM
06/27/19 10:17 AM
Hanover, Ontario, Canada
Moparmatty Offline
Moparmatty  Offline
EFI Source makes a complete plug and play ECU and harness setup for both early and late Gen 3 Hemi engines. No drive by wire option.
If you want to use an MS3Pro ECU you have to either make your own harness using their un-terminated harness, re-pin an EFI source harness to the MS3Pro ECU, or re-pin a factory harness and make it a standalone harness. No drive by wire option.
EFI source makes an adaptor plate so you can bolt on any cable drive GM LS style throttle body to the factory intakes. FAST makes bolt on cable driven throttle bodies for factory intakes with the correct GM TPS and IAC sensors that mate up with the EFI source harness.
If you want to have drive by wire going with a Holley Dominator ECU and Holley harnesses is the way to go.
You can also go the drive by cable route with Holley as well using the Dominator or HP ECU and their harnesses.
Matt Tebbutt
Ontario, Canada
Re: Any good stand alone controller ? [Re: Moparmatty] #2670686
06/27/19 01:31 PM
06/27/19 01:31 PM
Kalispell Mt.
Kalispell Mt.
Even better! I have a re-built VVT 5.7 here that the customer would rather have, I was figuring there was more likely a set up for the early engines than the VVT so this is perfect.
Re: Any good stand alone controller ? [Re: 65Dodge440] #2670876
06/27/19 08:14 PM
06/27/19 08:14 PM
Los Angeles, California
mdeane Offline
mdeane  Offline
The Mopar kit has been designed and tested by Mopar for 2013 and up VVT engines so be careful if using on pre 2013 engine. The computer in the kit is not locked so you can use a programmer to make any changes.
Re: Any good stand alone controller ? [Re: mdeane] #2672912
07/02/19 09:37 AM
07/02/19 09:37 AM
Ontario, Canada
D149 Offline
D149  Offline
Ontario, Canada
Does anyone know why the Mopar setup doesn't work with the truck engine? Are the sensors different, or just the wire lengths different. It's so much easier to find a truck engine, so I'm trying to figure out if the Mopar setup can be made to work.
1968 Valiant Signet 4dr. 273 4spd
1969 Road Runner 383 4spd
1969 Barracuda 318 auto
1970 Dart Swinger 340 4spd
1975 Cordoba 400-4bbl
1988 Caravelle 318 Auto
1999 Dakota R/T
2000 Viper GTS
2001 Ram 2500 Diesel 6spd
2018 Dodge Challenger GT (Winter beater!)
Re: Any good stand alone controller ? [Re: D149] #2673413
07/02/19 10:53 PM
07/02/19 10:53 PM
Australia
L4staero Offline
L4staero  Offline
Australia
Wire lengths are different, tuning is different due to different manifolds and cams etc
Re: Any good stand alone controller ? [Re: L4staero] #2674754
07/06/19 10:40 AM
07/06/19 10:40 AM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
We used the Mancini kit to put a 09 5.7 truck engine in my brother's T-bucket.
HemiTronix......AKA Nutter Racing in Vancover Washington has a kit desinged for the older G3s, I forget what the price was , in the end we used Mopars kit for the T-bucket when we decided to use the 09 engine.
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
