Any good stand alone controller ?
#2669493
06/24/19 07:01 PM
06/24/19 07:01 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Any easy harness and computer set up that will run with all the factory sensors on a take out early 5.7 engine?
Re: Any good stand alone controller ?
[Re: cbusters]
#2669664
06/25/19 07:34 AM
06/25/19 07:34 AM
Posts: 8,018 Tulsa OK
Bad340fish
Tulsa OK
Look at the EFI Source Gold Box. They have a nice plug and play harness.
If I were to go this route I would use an MS3Pro Evo or Ultimate and repin the EFI source harness to work. That is mainly because I have had good luck and service with DiyAutotune with my current EFI small block.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2669780
06/25/19 12:57 PM
06/25/19 12:57 PM
HotRodDave
Kalispell Mt.
The hemi 6 is only for ignition correct?
I been looking at the MS3Pro evo ultimate and now I am more confused than a termite in a wooden yo yo... I don't see a kit that says it if for the gen III hemi anywhere?
[Re: Bad340fish]
#2669888
06/25/19 06:54 PM
06/25/19 06:54 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
If I were to go this route I would use an MS3Pro Evo or Ultimate and repin the EFI source harness to work. That is mainly because I have had good luck and service with DiyAutotune with my current EFI small block. I would suggest an MS, but it does not support drive-by-wire, I took the original post as not wanting to change anything but just drop in the stock engine and go. The MS stuff isn't the most intuitive, however.
[Re: HotRodDave]
#2670009
06/25/19 11:53 PM
06/25/19 11:53 PM
Posts: 5,998 Salem
Grizzly
Moparts Proctologist
Salem
As expected, there is no answer to this question. Dave, I followed it for awhile and decided a few years ago: it's a lost cause. I can't believe it still needs to be said, but, the Daimler computer is un-crackable, and no BS "change-your-shift-points" sct, diablo or superchips amateur junk is ever going to cut the mustard. Some have claimed to have done it, and those that fell for it got their vehicle locked up and had to pay a dealership to fix the "tuner" mess. "Hemifever" comes to mind, I believe he is living under a new identity, lol. All I can offer is to go to a Blunder Motors based tuning platform and adapt it to run a Gen 3. It's a last resort, and has been done. To make matters worse, from what I've read lately, even they are going forward with locking up their new vehicles either this year or next. Or, hope for 350 cfm heads that don't leak water for $2000 a pair for LA/Magnum's.
Mo' Farts
Moderated by "tbagger".
[Re: HotRodDave]
#2670086
06/26/19 08:54 AM
06/26/19 08:54 AM
Posts: 836 Columbus, OH
65Dodge440
Columbus, OH
Hey HotRodDave, Isn't this designed for complete take outs and crate engines? https://www.manciniracing.com/mo5crheinkit.htmlA friend of mine used the 6.4 kit to put a 6.4 in a old Ford F100 and he said it couldn't have been simpler. I would go this route but my engine is far from stock so I got an MS3. Hopefully Mike helps me tune it when its finished.
[Re: 65Dodge440]
#2670181
06/26/19 12:40 PM
06/26/19 12:40 PM
Posts: 2,254 IL
furious70
IL
Hey HotRodDave, Isn't this designed for complete take outs and crate engines? https://www.manciniracing.com/mo5crheinkit.htmlA friend of mine used the 6.4 kit to put a 6.4 in a old Ford F100 and he said it couldn't have been simpler. I would go this route but my engine is far from stock so I got an MS3. Hopefully Mike helps me tune it when its finished. I don't believe the crate stuff uses the early sensors and such he's asking about. But yes, for later/crate stuff, this is definitely a write a check and install it option for a stock(ish) engine. A modified or boosted engine needs something different.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#2670251
06/26/19 02:45 PM
06/26/19 02:45 PM
HotRodDave
Kalispell Mt.
Now were getting somewhere, what sensors am I sposed to use with that mopar kit? And why does it look like there re two controllers?
[Re: HotRodDave]
#2670490
06/26/19 11:11 PM
06/26/19 11:11 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Now were getting somewhere, what sensors am I sposed to use with that mopar kit? And why does it look like there re two controllers? I believe it's a hair more complicated than just swapping sensors, I'm fairly certain the crank trigger wheel would need to be swapped. Which requires the crank to come out of the block. The "G3 Hemi Swap" facebook group may have some folks that have gone through that.
[Re: GoodysGotaCuda]
#2670540
06/27/19 07:25 AM
06/27/19 07:25 AM
Bad340fish
Tulsa OK
What is your goal? Do you just want to make a stock hemi run in a non OE application or do you want full tuning ability?
[Re: Bad340fish]
#2670593
06/27/19 10:17 AM
06/27/19 10:17 AM
Posts: 516 Hanover, Ontario, Canada
Moparmatty
EFI Source makes a complete plug and play ECU and harness setup for both early and late Gen 3 Hemi engines. No drive by wire option.
If you want to use an MS3Pro ECU you have to either make your own harness using their un-terminated harness, re-pin an EFI source harness to the MS3Pro ECU, or re-pin a factory harness and make it a standalone harness. No drive by wire option.
EFI source makes an adaptor plate so you can bolt on any cable drive GM LS style throttle body to the factory intakes. FAST makes bolt on cable driven throttle bodies for factory intakes with the correct GM TPS and IAC sensors that mate up with the EFI source harness.
If you want to have drive by wire going with a Holley Dominator ECU and Holley harnesses is the way to go.
You can also go the drive by cable route with Holley as well using the Dominator or HP ECU and their harnesses.
Matt Tebbutt Ontario, Canada
[Re: Moparmatty]
#2670686
06/27/19 01:31 PM
06/27/19 01:31 PM
HotRodDave
Kalispell Mt.
Even better! I have a re-built VVT 5.7 here that the customer would rather have, I was figuring there was more likely a set up for the early engines than the VVT so this is perfect.
[Re: mdeane]
#2672912
07/02/19 09:37 AM
07/02/19 09:37 AM
Posts: 105 Ontario, Canada
D149
Ontario, Canada
Does anyone know why the Mopar setup doesn't work with the truck engine? Are the sensors different, or just the wire lengths different. It's so much easier to find a truck engine, so I'm trying to figure out if the Mopar setup can be made to work.
Thanks Dave
1968 Valiant Signet 4dr. 273 4spd 1969 Road Runner 383 4spd 1969 Barracuda 318 auto 1970 Dart Swinger 340 4spd 1975 Cordoba 400-4bbl 1988 Caravelle 318 Auto 1999 Dakota R/T 2000 Viper GTS 2001 Ram 2500 Diesel 6spd 2018 Dodge Challenger GT (Winter beater!)
[Re: L4staero]
#2674754
07/06/19 10:40 AM
07/06/19 10:40 AM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
Wire lengths are different, tuning is different due to different manifolds and cams etc We used the Mancini kit to put a 09 5.7 truck engine in my brother's T-bucket. HemiTronix......AKA Nutter Racing in Vancover Washington has a kit desinged for the older G3s, I forget what the price was , in the end we used Mopars kit for the T-bucket when we decided to use the 09 engine.
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
