70 RR/GTX air grabber question #2669899
06/25/19 07:17 PM
06/25/19 07:17 PM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
So I have been on the hunt for 70 RR/GTX and I'm trying to learn as much as I can about specific options or tell tale signs of options. I have noticed on some AG cars there is a hole above the heater hoses and I've noticed some claimed AG cars do not have this hole. Was it hit or miss, was it a plant thing, was it a 4 speed vs automatic thing?
Separately I've run across some V code 4 speed cars without torque boxes, any hard rule there?
I'm been around long enough to know never say never and there are no absolutes.
Thanks in advance, Kevin
Careful, your character's showing!
Re: 70 RR/GTX air grabber question [Re: mopar346] #2669929
06/25/19 08:30 PM
06/25/19 08:30 PM
Midwest
O
On the edge 02 Offline
O
Midwest
If seen the hole above the heater hoses aswell. Think there is a dimple there from the factory. I used the dimple in 86 when I scored my A/G hood. Bought it right and wanted that hood so bad!!! Rick
Re: 70 RR/GTX air grabber question [Re: mopar346] #2669932
06/25/19 08:30 PM
06/25/19 08:30 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
only hemi and rag tops have torque boxes ,in 1970 b body. that look to me that where the a/g hoses go
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: 70 RR/GTX air grabber question [Re: 1969gtx] #2669962
06/25/19 09:28 PM
06/25/19 09:28 PM
mopar346 Offline OP
mopar346  Offline OP
So no torque boxes on V code 4 speeds in 70...……..interesting, yet on my 69 340 4 speed GTS, my 4 speed AAR, my 68 440 4 speed RT Coronet and my auto AC 69 RT Charger
Yes, from what I've seen the vacuum line pass through a grommet in that hole, are they on ALL factory AG cars? I understand it's a pressed hole as well not a cut hole, is that true?
I have seen the dimple on others as mentioned.
Re: 70 RR/GTX air grabber question [Re: mopar346] #2670002
06/25/19 11:19 PM
06/25/19 11:19 PM
Lansing, MI
70gtx440dana Online content
70gtx440dana  Online Content
Lansing, MI
The other location I have seen the a/g hoses pass through the firewall for 70 Plymouth is the dimple about 1' to the right of the one shown in the photo. Remember 70 B bodies with a/g option were made at 3 plants. LA, Lynch Road and St.Louis. If I remember right LA used a different hole location than LR and STL. Hopefully someone will post a few photos.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70 RR/GTX air grabber question [Re: 70gtx440dana] #2670046
06/26/19 06:12 AM
06/26/19 06:12 AM
mopar346 Offline OP
mopar346  Offline OP
Thank you good info guys.
"The other location I have seen the a/g hoses pass through the firewall for 70 Plymouth is the dimple about 1' to the right of the one shown"
is it the same height or down less visible like behind the valve cover or engine?
Can anyone answer the question if drilled or drilled and does anyone know of a legit AG car with a hole in one of these 2 locations?
Re: 70 RR/GTX air grabber question [Re: mopar346] #2670054
06/26/19 06:44 AM
06/26/19 06:44 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
All AG cars have to have a hole so that the vacuum lines can pass through the fire wall to the switch.
I don't have the pictures on this computer but I can provide the location for a legit AG car from St Louis
Re: 70 RR/GTX air grabber question [Re: Morty426] #2670383
06/26/19 08:07 PM
06/26/19 08:07 PM
mopar346 Offline OP
mopar346  Offline OP
Please and thank you!
Re: 70 RR/GTX air grabber question [Re: mopar346] #2670466
06/26/19 09:56 PM
06/26/19 09:56 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
are talking the box in front of the rear leaf spring as far as a torque boxes
Re: 70 RR/GTX air grabber question [Re: 1969gtx] #2670478
06/26/19 10:24 PM
06/26/19 10:24 PM
mopar346 Offline OP
mopar346  Offline OP
Yes, my best description is you have to reach up into the box to remove the front leaf spring hanger nuts. Or at least that is what I think of as torque boxes, the front has extra support as well but not sure how I would describe them.
Re: 70 RR/GTX air grabber question [Re: mopar346] #2670874
06/27/19 08:09 PM
06/27/19 08:09 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
On a 68/70 b body that box was only on hemi or rag top if you have any other b body with them some one put them on
