Rod bearings BBMope not BBChev #2668901
06/23/19 12:57 AM
06/23/19 12:57 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
540-in motor. 4.500 stroke, steel rods. Pump gas, not real outrageous on the RPM.
Clevite - King - Sealed Power..............??
I think the crank is hardchromed ( if that makes a difference in bearing choice).
Also, I have Std size journals.
I'm not opposed to increasing the clearance by grinding the journals 1 or 2 thou if necessary.
What I'm most concerned with is bearing quality these days.
Which bearing do you like ?
Re: Rod bearings BBMope not BBChev [Re: hemienvy] #2668905
06/23/19 01:25 AM
06/23/19 01:25 AM
New York, USA
Chargerfan68 Offline
New York, USA
I have always used clevite in all my past builds until the last 2. I used King main bearings in the last 2 stroker motors and was very impressed with the quality and consistency. The Clevites served me well also.
Re: Rod bearings BBMope not BBChev [Re: Chargerfan68] #2668948
06/23/19 08:08 AM
06/23/19 08:08 AM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
I think which ever one you use will be fine. I don't believe any of those are going to "fail" on you. I've used all three and they worked. I don't recall if any brand "fit" better than the others. Maybe I should have paid more attention. I often have to use 1/2 of another size on a few throws. My default bearing is Clevite.
2011 Drag Pak Challenger
Re: Rod bearings BBMope not BBChev [Re: hemienvy] #2668980
06/23/19 10:27 AM
06/23/19 10:27 AM
I've found that the king bearing have a little ( .0005 to .0015) more clearances than Clevite P or HD bearings or Federal Mogul do on a high side standard rod journal shruggy
I do like to have at least .0025 + rod and bearing clearances on the Mopar rod size journals, .0035 + on the mains up
Re: Rod bearings BBMope not BBChev [Re: Cab_Burge] #2669010
06/23/19 11:59 AM
06/23/19 11:59 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I like the King bearings... like Cab said.. they do tend to be a bit larger
so that helps when you want/need a little more clearance.. I just put
a set in my stroker SB to gain a little clearance
wave
