Re: Rod bearings BBMope not BBChev
[Re: hemienvy]
#2668905
06/23/19 01:25 AM
06/23/19 01:25 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I have always used clevite in all my past builds until the last 2. I used King main bearings in the last 2 stroker motors and was very impressed with the quality and consistency. The Clevites served me well also.
[Re: Chargerfan68]
#2668948
06/23/19 08:08 AM
06/23/19 08:08 AM
Posts: 2,678 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I think which ever one you use will be fine. I don't believe any of those are going to "fail" on you. I've used all three and they worked. I don't recall if any brand "fit" better than the others. Maybe I should have paid more attention. I often have to use 1/2 of another size on a few throws. My default bearing is Clevite.
2011 Drag Pak Challenger
[Re: Cab_Burge]
#2669010
06/23/19 11:59 AM
06/23/19 11:59 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I like the King bearings... like Cab said.. they do tend to be a bit larger so that helps when you want/need a little more clearance.. I just put a set in my stroker SB to gain a little clearance ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
