I need more power #2668034
06/20/19 03:58 PM
06/20/19 03:58 PM
East Brunswick New Jersey
N
NoFrills Offline OP
NoFrills  Offline OP
N
I am going to be running my small block dart at drag week and I need some help getting some more power. Car works well all steel lexan 1/4 windows. It weights 3200 and change with me in it. Dana Caltracs 727 and a cage. The current engine is a 340 block .040 with a scat 360 steal crank and rods flat top pistons. It is 10.2 to 1 with a set of ported x heads. Has a 591 lift 240@50 solid roller cam. There is a 1000 cfm cra on a ported strip dominator. The engine has gone 10.89 at 125 but will ran best of 11.20 120 in the heat. Would like it to run comfortably in the 10s for drag week. I'm thinking I need at least another 50 hp dont want to spray it. I have a set of ported w2 that I think will be going on it. A crank scraper is on the way. Also thinking about changing the cam always thought it needed more. Any input would be appreciated.
Re: I need more power [Re: NoFrills] #2668040
06/20/19 04:32 PM
06/20/19 04:32 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
My suggestion is look for places to drop weight out of the car. LOTS of places you can trim lbs out of a car. At your performance level should not take a lot of work to find 50hp worth of excess weight in the car
Re: I need more power [Re: Al_Alguire] #2668044
06/20/19 04:42 PM
06/20/19 04:42 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Changing the heads will be the quickest fix. No doubt about it
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: I need more power [Re: B3422W5] #2668208
06/21/19 01:40 AM
06/21/19 01:40 AM
iagree
Taking weight out also is always a good thing to do up devil
Re: I need more power [Re: Cab_Burge] #2668220
06/21/19 04:53 AM
06/21/19 04:53 AM
N
NoFrills Offline OP
NoFrills  Offline OP
N
I would like to get it around 3000 with me in it. The dana and 727 are weighing it down a bit. Did pick up.a glass hood. The only problem is 200 lbs is not going g to get me to where I want to be.
Re: I need more power [Re: NoFrills] #2668224
06/21/19 06:54 AM
06/21/19 06:54 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
A good set of aluminum heads will add power and drop nose weight at the same time. Find something compatible with your intake, valvetrain and headers to minimize cost of swap. Maybe a set of 1.6 rockers, too.
Re: I need more power [Re: sgcuda] #2668244
06/21/19 08:27 AM
06/21/19 08:27 AM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
A 904 with an aluminum drum is good for .1 to .15 VS the 727 .
Re: I need more power [Re: NoFrills] #2668269
06/21/19 09:51 AM
06/21/19 09:51 AM
Nevada
merpar Offline
merpar  Offline
Nevada
I'm with Alguire, loose the weight. Look the car over, 200 lbs should be easy. My first car I scraped all the undercoating off and weighed it. Was over 25 lbs. Glass bumpers with aluminum brackets. You will be surprised how quick it adds up.
Re: I need more power [Re: merpar] #2668294
06/21/19 10:50 AM
06/21/19 10:50 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Not the cheapest....... but probably the “easiest”.
408/416 stroker with some tweaked aluminum heads.
Basically, a 4” cast crank and a set of off the shelf pistons swapped into the current motor, and better heads.
Re: I need more power [Re: fast68plymouth] #2668328
06/21/19 11:58 AM
06/21/19 11:58 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
How much fuel do you run in the car? I lost easily 70 lbs going from 5/8ths a tank to 2 gallons. Installed holley
Hydramat to be able to run that little fuel. Could probably run less but the gauge just starts to move and I like knowing I have enough.
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: I need more power [Re: fast68plymouth] #2668331
06/21/19 12:06 PM
06/21/19 12:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With your weight the stroker 416 would help a lot.. it would add the
torque you need and look at the weight.. will you be running a back seat
if you are you might want to take that out plus the fiberglass hood and
manual hinges with a prop rod.. battery in the trunk.. just a couple of
things.. have fun on DW.. its usually pretty damn hot
wave
Re: I need more power [Re: MR_P_BODY] #2668372
06/21/19 01:49 PM
06/21/19 01:49 PM
N
NoFrills Offline OP
NoFrills  Offline OP
N
I do have a 418 short deck r3 but its 13:1 and dont really want to buy race gas for the whole trip. The car is fairly lightened. No back seat or heater. Most of the brackets are gone or swiss cheesed. Usually run it with around 7 to 10 gallons of fuel. Would like to put a set of trickflow heads on it but am waiting on a coupon or Ebay sale.
Re: I need more power [Re: NoFrills] #2668373
06/21/19 01:51 PM
06/21/19 01:51 PM
N
NoFrills Offline OP
NoFrills  Offline OP
N
When I 1st got the car it had a glass front bumper. My kids where messing around in it and rolled it off the trailer into the garage. Glass bumpers are not kid compliant.
Re: I need more power [Re: NoFrills] #2668379
06/21/19 02:01 PM
06/21/19 02:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Throw A set of pistons in it for 11:1 with the proper cam and you
can run pump gas
wave
Re: I need more power [Re: NoFrills] #2668396
06/21/19 03:05 PM
06/21/19 03:05 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Keep your eyes open or make a post on Monday that you need a Jegs or Summit 10% off code. Jegs and Summit will both be at Norwalk for the NHRA race and will probably be passing them out. I would have loved to go but with all the rain I'm way behind with yardwork.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: I need more power [Re: pittsburghracer] #2668407
06/21/19 03:33 PM
06/21/19 03:33 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I’m at 12.2 to 1 and am going to run pump gas for the road portion. Empty the tank at the track and put in race fuel. Did a 30 mile test with pump gas. No detonation, just baby the snot out of it. You could mix in a little race fuel as you go.
Re: I need more power [Re: NoFrills] #2668417
06/21/19 03:52 PM
06/21/19 03:52 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
THIS^^^^, Add a set of Trick Flow heads along with a cam that's in the 260's @ .050.
Hear ya on the race gas. What about E85??
Re: I need more power [Re: cudadoug] #2668424
06/21/19 04:12 PM
06/21/19 04:12 PM
N
NoFrills Offline OP
NoFrills  Offline OP
N
I thought about going e85 but the closest station is about 30 miles away next closest is over 50
Re: I need more power [Re: NoFrills] #2668464
06/21/19 05:53 PM
06/21/19 05:53 PM
WA 98043
thecarfarmer Offline
WA 98043
Sounds like a good way to build some extra drama into the trip, looking for fuel that ain't readily available...
Just my .02; best of luck
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: I need more power [Re: NoFrills] #2668501
06/21/19 08:08 PM
06/21/19 08:08 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I carry my methanol with me - it's in my Snow water injection tank.
Light throttle use: lasts a month.
At 30 psi: much less.
Boffin Emeritus
