69 park lamp pigtail removal #2666839
06/17/19 11:22 AM
06/17/19 11:22 AM
GA
roadrunninMark Offline OP
GA
On my 69 RR, my one park lamp (bumper mounted) has a rusted out bulb socket. The housing is fine, I am looking to change out the socket-pigtail. I bought another housing/pigtail from an a body and want to swap the good one into mine. Has anyone tried this and know the proper way without messing up either the housing or the pigtail/socket? It appears to be crimped in on the inside of the housing; where the bulb goes.
Just trying to get some good advice from someone who has done this before I attempt it. The B body housings are not reproduced and are hard to find, so I am trying this way first. Pics of what I got and then the new one that is on the way:
Thanks,
Mark
Re: 69 park lamp pigtail removal [Re: roadrunninMark] #2666878
06/17/19 12:49 PM
06/17/19 12:49 PM
I would imagine that you would need to crimp the socket inward till it is free to come out the front of the housing & maybe do some dremeling
Re: 69 park lamp pigtail removal [Re: roadrunninMark] #2666957
06/17/19 04:49 PM
06/17/19 04:49 PM
cbusters Offline
cbusters  Offline
Thanks,
Mark
I cut the old socket off with a cutoff wheel and worked the little pieces until the socket pieces came out of the housing. I cut the rear of the donor housing off and sliced the housing parts until they wiggled off the socket. I had one split on the socket flange and "screwed" it into the good housing like a screw. I slid the pig tail into a piece of conduit and used the tapered 1/2 drive sockets like punches to roll the crimped part back flat and then a kingpin that I had from a past project to flatten out the "ring" and get good contact for current.
Re: 69 park lamp pigtail removal [Re: cbusters] #2666961
06/17/19 05:04 PM
06/17/19 05:04 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
How about fitting it with a replacement snap in socket like this. https://www.ebay.com/itm/Pico-5441C-Universal-Tail-Light-Socket/133082038031?
Re: 69 park lamp pigtail removal [Re: roadrunninMark] #2667077
06/18/19 03:15 AM
06/18/19 03:15 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Send me your old ones, for $35, I'll press new ones in both.
Re: 69 park lamp pigtail removal [Re: HEMICUDA] #2667081
06/18/19 03:45 AM
06/18/19 03:45 AM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
Man, if it were me, this is what I would do.
Scott
1969 Super Bee, 383/4 speed
Re: 69 park lamp pigtail removal [Re: HEMICUDA] #2667088
06/18/19 06:13 AM
06/18/19 06:13 AM
BDW Offline
BDW  Offline
Do this!
Mike replaced my Challenger pigtails, there was no way I could got this done myself, and the work was flawless.
Thx again Mike, you’re truly an asset to the hobby.
Re: 69 park lamp pigtail removal [Re: BDW] #2667115
06/18/19 08:56 AM
06/18/19 08:56 AM
GA
GA
Oh man, I wish I had asked this question before I bought the other housing! I'll give it a try myself then if it doesn't work, I'll send the one to you Mike. I just need the one done.
Re: 69 park lamp pigtail removal [Re: HEMICUDA] #2667173
06/18/19 12:16 PM
06/18/19 12:16 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Mike, that is really good to know you can do this!!
-Eric
