Re: 72 Duster Directionals not working
[Re: MrMayhem]
#2666833
06/17/19 11:19 AM
06/17/19 11:19 AM
Posts: 20,179 Park Forest, IL
slantzilla
Park Forest, IL
Aren't turn signals and hazards on different flashers?
[Re: stumpy]
#2666848
06/17/19 11:39 AM
06/17/19 11:39 AM
RapidRobert
swap the (2) flasher cans & see if the open follows it. From the connectors behind the drivers side kick panel the circuits are the same rearward from there (large filament(s) in the 1157 taillight bulbs) so work upstream from there if the flasher can ain't it.
[Re: MrMayhem]
#2666922
06/17/19 02:17 PM
06/17/19 02:17 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
The two flashers are located;one next to fuse box and the other is behind the ashtray.
The blue wires behind the kick panel that are disconnected go to the key buzzer either/or seatbelt buzzer. Ignore unless you like listening to the most annoying sound in the world..
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
[Re: 68Cbarge]
#2667133
06/18/19 10:20 AM
06/18/19 10:20 AM
Posts: 19,408 north of coder
moparx
take those buzzer units and make up two [very] long jumper leads. use this "test" instrument for chasing wiring issues. works great !
