Re: Suggestions on what to do with my motor? - update
[Re: 440Jim]
#2779543
05/29/20 05:25 PM
05/29/20 05:25 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
I am looking forward to the dyno results. Not too many 1000+ hp engines posted here. Can you summarize the final build numbers? 15.x CR, cam specs, head flow numbers, carb, header size I will when after the dyno run.
[Re: markz528]
#2779568
05/29/20 06:39 PM
05/29/20 06:39 PM
Guitar Jones
Hmm, that's not your run of the mill 500 horse 440. I also noticed you don't have a PH8A Fram oil filter on it. Good luck with it, hope it's everything you wanted from it.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#2779570
05/29/20 06:40 PM
05/29/20 06:40 PM
Guitar Jones
Oh wait, are you going to put a Street Demon on it?
[Re: gregsdart]
#2779695
05/30/20 10:12 AM
05/30/20 10:12 AM
markz528
Morrow, OH
Did i miss when the dyno session is? Looking forward to this! It is what i should have done many years ago!! Dyno session not scheduled yet.
[Re: markz528]
#2780812
06/02/20 05:15 PM
06/02/20 05:15 PM
markz528
Morrow, OH
June 17 is dyno day..............
[Re: markz528]
#2781379
06/04/20 12:58 PM
06/04/20 12:58 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
June 17 is dyno day.............. Cant wait to hear the results. The little B1 deal was just dynode on this past Monday
[Re: gregsdart]
#2781428
06/04/20 04:20 PM
06/04/20 04:20 PM
markz528
Morrow, OH
June 17 is dyno day.............. Any chassis or driveline upgrades to match the new power level? Not much. Biggest worry is the 727 output shaft. Working with Rick Allison on a solution but that is still open. John Holt redid my fuel tank and added the parachute. They also redid my windshield as it was caving in at 140 mph. The window was in original rubber and the Lexan was cut a tad too small. Now its screwed in.
[Re: markz528]
#2786295
06/17/20 10:47 AM
06/17/20 10:47 AM
markz528
Morrow, OH
Well its dyno day! Anyone wanna play a guessing game on HP? I know I did not give the required info.......... I say it best make 1050 and hope at least 1080 hp.
[Re: markz528]
#2786299
06/17/20 11:00 AM
06/17/20 11:00 AM
Al_Alguire
Las Vegas
My old MC engine made 1088 and was only 525, so lets start there. Good luck and I am sure you will be happy with what Tony and BES give you.
[Re: HardcoreB]
#2786371
06/17/20 01:00 PM
06/17/20 01:00 PM
Posts: 4,675 On the parachute mount
n20mstr
MY 530" made 915, with C23 and has a nitrous friendly 1050 carb and nitrous no NA friendly cam LOL , so I don't see how 1000+ is out of the question. Should go over 1000. I will guess 1100
....BAD A$$ STREET CAR.....
[Re: markz528]
#2786433
06/17/20 02:45 PM
06/17/20 02:45 PM
Posts: 16,925 NC
440Jim
NC
Well its dyno day! Anyone wanna play a guessing game on HP? I don't know much about those B1 MC motors, and without the cam duration guessing peak horsepower is tough. My guess 1065 hp at 6800 rpm More cam, more rpm, more peak horsepower. Good Luck.
[Re: 440Jim]
#2786445
06/17/20 03:04 PM
06/17/20 03:04 PM
markz528
Morrow, OH
We are running c14 fuel. My headers did not fit so these are a bit bigger than mine.
We will see where it ends up so far 1040 hp at 7100 rpm 830 torque. It likes timing.
