Page 4 of 4 1 2 3 4
Re: Anyone run Ford TFI coil+HEI module with mopar distributor? [Re: mopower440] #2661848
06/03/19 12:58 PM
06/03/19 12:58 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
The 4 pin module is really the one to use with this basic swap, where you're carbureted and are controlling advance with a mopar distributor.
I have not researched this to death and don't feel I know all the ins and outs of it, but I believe the 7 pin or 8 pin module is still useful...
I believe it is the one you want to use with EFI/megasquirt with the computer providing spark control.
Rich H.
Esse Quam Videri
Re: Anyone run Ford TFI coil+HEI module with mopar distributor? [Re: ZIPPY] #2663839
06/08/19 07:33 PM
06/08/19 07:33 PM
middle Tennessee
mopower440 Offline
mopower440  Offline
middle Tennessee
Got the 4 pin installed today and its all good now. no more advance getting thrown in on top of whats supposed to be there. Now to buy a spare 4 pin to carry with me. I had 4 of the 8 pins for back ups..Wish i could trade a couple for some 4 pins.
Re: Anyone run Ford TFI coil+HEI module with mopar distributor? [Re: mopower440] #2669990
06/25/19 10:36 PM
06/25/19 10:36 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
If you like to mount the module off the distributor like I do to get it away from some heat. Try this bracket, AC Delco #10474610. Just drill 2 new holes and it works great and is under $20.
The only Carbs I care about are under the hood!
Re: Anyone run Ford TFI coil+HEI module with mopar distributor? [Re: Azzkikrcuda] #2670075
06/26/19 08:17 AM
06/26/19 08:17 AM
middle Tennessee
mopower440 Offline
mopower440  Offline
middle Tennessee
I like that!
Re: Anyone run Ford TFI coil+HEI module with mopar distributor? [Re: mopower440] #2670082
06/26/19 08:43 AM
06/26/19 08:43 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
You can mount the module on the back of the heat sink and not have to drill any extra holes.
Used long through-screws to get the necessary clearance for mounting to fender housing.
Joe
PS, don't forget the paste for heat transfer
Re: Anyone run Ford TFI coil+HEI module with mopar distributor? [Re: Azzkikrcuda] #2670108
06/26/19 09:49 AM
06/26/19 09:49 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
That heat sink is a nice addition, thank you!
I'm thinking a couple stand offs for mounting would help the heat situation even more.
Rich H.
Esse Quam Videri
Re: Anyone run Ford TFI coil+HEI module with mopar distributor? [Re: ZIPPY] #2670153
06/26/19 11:53 AM
06/26/19 11:53 AM
would it be better to have it mounted flush with some heat sink paste to wick away heat produced in the module (like it is in the HEI dist) or to space it up to isolate it from heat in this metal mounting bracket itself?
Re: Anyone run Ford TFI coil+HEI module with mopar distributor? [Re: RapidRobert] #2670578
06/27/19 09:46 AM
06/27/19 09:46 AM
moparx Offline
moparx  Offline
after seeing that finned mounting bracket [up] i would use the paste on the bracket, then space it away from the surface 1/4-3/8" with a couple of bushings from the hardware store.
just my opinion. it couldn't hurt, and would be easy to do.
beer
Page 4 of 4 1 2 3 4
