pulled axle and thrust button fell out,now what? #2662757
06/05/19 06:19 PM
06/05/19 06:19 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
Working on a 70 challenger 8 3/4 with leaky axle seals,pulled the axles and the thrust button fell out and dissapeared on pass side,am I pulling the pumpkin now to retrieve it or does anyone know an easier way?
Im a newbie to working on 8 3/4's.......
Re: pulled axle and thrust button fell out,now what? [Re: ogopogo] #2662776
06/05/19 06:58 PM
06/05/19 06:58 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
You can attach a magnet to a long flexible rod and fish it out. Maybe would help to pull the other axle out.
Re: pulled axle and thrust button fell out,now what? [Re: ogopogo] #2662782
06/05/19 07:08 PM
06/05/19 07:08 PM
cbusters Offline
cbusters  Offline
I installed one of these in my driveway with 2 broomsticks and tape way back when.
Re: pulled axle and thrust button fell out,now what? [Re: cbusters] #2662802
06/05/19 08:04 PM
06/05/19 08:04 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
Ok so Ill try the magnet and rod,if i get it back,any ideas how to put it back in position?
Re: pulled axle and thrust button fell out,now what? [Re: ogopogo] #2662823
06/05/19 08:43 PM
06/05/19 08:43 PM
blewbyu Offline
blewbyu  Offline
Buttons are only on the clutch sure grips. The cones have a hole and it may look like the button is missing but does not use a button twocents
Re: pulled axle and thrust button fell out,now what? [Re: blewbyu] #2662871
06/05/19 10:53 PM
06/05/19 10:53 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Best to jsta pull the pig ... THEN reinstall the buttons properly!
Re: pulled axle and thrust button fell out,now what? [Re: ogopogo] #2662932
06/06/19 06:06 AM
06/06/19 06:06 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
It's VERY difficult. What worked for me, a vacuum cleaner with two extensions, two smaller diameter short extensions with LOTS of electrical tape to attach and make up the difference in diameter, then ending in a piece of fresh fuel line cut very square on the end. Turn on vacuum, put head of thrust button to the hose and maneuver it into place, when you get it there, turn off vacuum. Other than that, remove the center section.
I'd be interested in seeing if anybody else did this another way without removing the center section. What I did was my last desperate plan before giving up. Nothing else I tried even came close to success.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: pulled axle and thrust button fell out,now what? [Re: 3hundred] #2662933
06/06/19 06:10 AM
06/06/19 06:10 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
By the time you do all this maneuvering to get this out, you could pull the pig to get it out and install it properly. If you don’t install it, you will never get the axles to proper preload. Pull it and install a new trust button.
Re: pulled axle and thrust button fell out,now what? [Re: fastmark] #2662941
06/06/19 07:16 AM
06/06/19 07:16 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Be a good opportunity to change the oil and clean out the housing. Take a good look at the pig while you've got it out, too.
Re: pulled axle and thrust button fell out,now what? [Re: bobby66] #2662971
06/06/19 09:17 AM
06/06/19 09:17 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
And convert over to Green Bearings, toss the thrust button/ axle end adjuster....might as well add 4 wheel discs also... A win, win situation IMHO
Re: pulled axle and thrust button fell out,now what? [Re: ogopogo] #2662995
06/06/19 10:16 AM
06/06/19 10:16 AM
AndyF Offline
AndyF  Offline
Well the good news is that you won't be a newbie by the time you have it all back together!
Re: pulled axle and thrust button fell out,now what? [Re: AndyF] #2663029
06/06/19 12:09 PM
06/06/19 12:09 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I’ve done it, extendable magnet taped to a stick. Position the plug on the magnet and slide in the hole and hold it there. Take another wooden stick and slide it in and hold the plug in place. Pull out the stick with the magnet. A little grease on the plug will help hold it in place after you pull both sticks out. Took longer to type this than do it.
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: pulled axle and thrust button fell out,now what? [Re: fastmark] #2663092
06/06/19 02:02 PM
06/06/19 02:02 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Can I have an AMEN!!
Re: pulled axle and thrust button fell out,now what? [Re: 6PakBee] #2663529
06/07/19 03:00 PM
06/07/19 03:00 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
Well i am the impatient type and didnt fele like pulling the pumpkin unless I had to so rigged up a piece or ready rod with a magnet dangling on the end and fished out both buttons in seconds flat! stuck them back in with a coat hanger and some sticky grease on them to hold em !
Re: pulled axle and thrust button fell out,now what? [Re: ogopogo] #2663545
06/07/19 04:15 PM
06/07/19 04:15 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: pulled axle and thrust button fell out,now what? [Re: ogopogo] #2663641
06/07/19 09:47 PM
06/07/19 09:47 PM
cbusters Offline
cbusters  Offline
Do you realize they are held in with a roll pin?
Re: pulled axle and thrust button fell out,now what? [Re: cbusters] #2663763
06/08/19 11:32 AM
06/08/19 11:32 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
as mentioned, they get a roll pin. Get them rightly installed... remove pumpkin and do it right
Re: pulled axle and thrust button fell out,now what? [Re: NachoRT74] #2663776
06/08/19 12:38 PM
06/08/19 12:38 PM
cbusters Offline
cbusters  Offline
It can be done with the 3rd member in. In my first post I mentioned two broomsticks and I set the pin in one spacer and taped it to the end and the other side the same way. Slide them in and have someone hold the other side tight and tap the spacers together. I found that someone had lost them and put two adjustable axles in to make up the difference.
Re: pulled axle and thrust button fell out,now what? [Re: cbusters] #2663792
06/08/19 02:29 PM
06/08/19 02:29 PM
BDW Online content
BDW  Online Content
Is that really a must have?
With the axles in, where can they go?
Re: pulled axle and thrust button fell out,now what? [Re: BDW] #2663796
06/08/19 02:51 PM
06/08/19 02:51 PM
A727Tflite Online content
A727Tflite  Online Content
Maybe the ring and pinion will find the roll pin for you.
