B-body K-member attach bolt threads #2663172
06/06/19 06:25 PM
06/06/19 06:25 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey Gang...
I'm in the process of starting to restore 69 Charger 500.... Question; are the threads in the front framerails for the k-member attach bolts tampered or standard threading. I'm looking to clean them up since there is some corrosion in there... But, don't want to ruin the threads of a run a tab in them...
Thanks..
Troy
Houston Mopar Connection Club
Re: B-body K-member attach bolt threads [Re: hemi68charger] #2663178
06/06/19 06:29 PM
06/06/19 06:29 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
If you look at one of the bolts it will answer your question.
Re: B-body K-member attach bolt threads [Re: Stanton] #2663196
06/06/19 07:06 PM
06/06/19 07:06 PM
Houston, Tx
Houston, Tx
I have, not green around the ears, but also wanna be better safe than sorry... My gut says they aren't tampered, but I'd rather get a second opinion...
Thanks..
Troy
Re: B-body K-member attach bolt threads [Re: hemi68charger] #2663223
06/06/19 08:03 PM
06/06/19 08:03 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
The threads are not tapered, but the bolts have a bit of a tapered shank to help center the frames on installation, I believe.
Re: B-body K-member attach bolt threads [Re: hemi68charger] #2663229
06/06/19 08:15 PM
06/06/19 08:15 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Threads are a straight thread tap. 5/8" coarse thread going off memory
Bolts are as well...but have a shoulder on them to position the K frame
Re: B-body K-member attach bolt threads [Re: buildanother] #2663234
06/06/19 08:28 PM
06/06/19 08:28 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Are you sure about that? Everyone I have has a taper at the start of threads. I probably have about 100
Re: B-body K-member attach bolt threads [Re: Morty426] #2663246
06/06/19 08:48 PM
06/06/19 08:48 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Arpie you sure about that? Everyone I have has a taper at the start of threads. I probably have about 100
Bolts have a pilot point to aid starting them but has nothing to do with thread pitch .
Re: B-body K-member attach bolt threads [Re: gtx6970] #2663255
06/06/19 08:57 PM
06/06/19 08:57 PM
Houston, Tx
Houston, Tx
Thanks guys... Wanted to make sure....
Troy
Re: B-body K-member attach bolt threads [Re: gtx6970] #2663337
06/07/19 02:50 AM
06/07/19 02:50 AM
iagree
I've taken a bunch of Mopar K members out of A,B,E and even a few C body cars, all of them use the same type bolts with the tapered ends with the cleaning slots in the bottom starter threads scope
Re: B-body K-member attach bolt threads [Re: Cab_Burge] #2663345
06/07/19 03:41 AM
06/07/19 03:41 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Re: B-body K-member attach bolt threads [Re: kentj340] #2663481
06/07/19 12:48 PM
06/07/19 12:48 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
5/8? I figured they were larger. Been awhile since I changed a K-member.
2011 Drag Pak Challenger
