B-body K-member attach bolt threads
#2663172
06/06/19 06:25 PM
06/06/19 06:25 PM
Posts: 8,827 Houston, Tx
hemi68charger
Houston, Tx
Hey Gang...
I'm in the process of starting to restore 69 Charger 500.... Question; are the threads in the front framerails for the k-member attach bolts tampered or standard threading. I'm looking to clean them up since there is some corrosion in there... But, don't want to ruin the threads of a run a tab in them...
Thanks.. T
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: B-body K-member attach bolt threads
[Re: Stanton]
#2663196
06/06/19 07:06 PM
06/06/19 07:06 PM
hemi68charger
Houston, Tx
If you look at one of the bolts it will answer your question. I have, not green around the ears, but also wanna be better safe than sorry... My gut says they aren't tampered, but I'd rather get a second opinion... Thanks..
[Re: buildanother]
#2663234
06/06/19 08:28 PM
06/06/19 08:28 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
The threads are not tapered, but the bolts have a bit of a tapered shank to help center the frames on installation, I believe. Are you sure about that? Everyone I have has a taper at the start of threads. I probably have about 100
[Re: Morty426]
#2663246
06/06/19 08:48 PM
06/06/19 08:48 PM
Posts: 21,397 It's a dry heat
gtx6970
It's a dry heat
The threads are not tapered, but the bolts have a bit of a tapered shank to help center the frames on installation, I believe. Arpie you sure about that? Everyone I have has a taper at the start of threads. I probably have about 100 Bolts have a pilot point to aid starting them but has nothing to do with thread pitch .
[Re: gtx6970]
#2663255
06/06/19 08:57 PM
06/06/19 08:57 PM
hemi68charger
Houston, Tx
Thanks guys... Wanted to make sure....
[Re: gtx6970]
#2663337
06/07/19 02:50 AM
06/07/19 02:50 AM
Posts: 43,097 Bend,OR USA
Cab_Burge
The threads are not tapered, but the bolts have a bit of a tapered shank to help center the frames on installation, I believe. Arpie you sure about that? Everyone I have has a taper at the start of threads. I probably have about 100 Bolts have a pilot point to aid starting them but has nothing to do with thread pitch . I've taken a bunch of Mopar K members out of A,B,E and even a few C body cars, all of them use the same type bolts with the tapered ends with the cleaning slots in the bottom starter threads
