E body Oil pressure sending unit wire #2663099
06/06/19 02:28 PM
06/06/19 02:28 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
Does anybody know where to find a replacement wire for the one that slides on the tab on top of the oil pressure sending unit for and E body? I put a brand new engine harness in the car and the gray wire from the bulkhead connector for the oil pressure sender is only a few inches long with a female bullet style connector on it. Does anybody sell the short piece with the male bullet connector and the terminal end that slides onto the oil pressure sender? I cant seem to find anything. Thanks
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: E body Oil pressure sending unit wire [Re: 73cuda340] #2663140
06/06/19 05:13 PM
06/06/19 05:13 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
The wire on my 70 e bodies comes out of the harness and straight to the sender with a special terminal and no bull it connector at all.
Re: E body Oil pressure sending unit wire [Re: fastmark] #2663149
06/06/19 05:38 PM
06/06/19 05:38 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Call Frank Baldason, he might have something
Re: E body Oil pressure sending unit wire [Re: 71birdJ68] #2663154
06/06/19 05:52 PM
06/06/19 05:52 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
I'am sure he has the terminal end.
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: E body Oil pressure sending unit wire [Re: VCODE] #2663155
06/06/19 05:55 PM
06/06/19 05:55 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I have used generic female terminal ends from the hardware store. They come in different sizes.
Re: E body Oil pressure sending unit wire [Re: 73cuda340] #2663157
06/06/19 05:57 PM
06/06/19 05:57 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Could always make your own ??? . . . . a piece of wire, correct connectors on each end . . . voila . . .
Re: E body Oil pressure sending unit wire [Re: 73cuda340] #2663173
06/06/19 06:25 PM
06/06/19 06:25 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
I should be putting a new M&H harness in sometime in the next couple weeks. If you can wait, I'll send you my old one. I think it has about 5" of wire from the connector where someone spliced it.
Re: E body Oil pressure sending unit wire [Re: a12rag] #2663261
06/06/19 09:10 PM
06/06/19 09:10 PM
clarks summit pa
clarks summit pa
I planned on making my own originally. I have the bullet connectors but I cant seem to find the connector that goes on the sending unit. Thanks for the pictures
Re: E body Oil pressure sending unit wire [Re: gzig5] #2663264
06/06/19 09:12 PM
06/06/19 09:12 PM
clarks summit pa
clarks summit pa
Ok thanks. Ill see if I can find anything first, if not I'll let you know. Im not in a big hurry, I'm having a bunch of issues with my new motor, so unfortunately there's going to be some downtime.
