jegs universal radiators OR cooling tricks ? #2662263
06/04/19 01:54 PM
06/04/19 01:54 PM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
Any one use one of these?
Right now I use a Mazda MPV radiator. And while its light, its just one row 1" is not really cutting it.
Its either buy a golf cart to tow up , or get a bigger rad. These Jegs are two row 1" so its basically double what I have now.
....BAD A$$ STREET CAR.....
Re: jegs universal radiators [Re: n20mstr] #2662298
06/04/19 04:27 PM
06/04/19 04:27 PM
K
KOS Offline
KOS  Offline
K
I use a summit brand which is actually made by Northern has their name stamped right on it.....awsome piece 2row 1" around $150
Re: jegs universal radiators [Re: KOS] #2662330
06/04/19 06:58 PM
06/04/19 06:58 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Me as well, a cross flow aluminum northern, for about the same price. It's been one of the better pieces on my car....
Rich H.
Esse Quam Videri
Re: jegs universal radiators [Re: n20mstr] #2662336
06/04/19 07:16 PM
06/04/19 07:16 PM
K
Kiddart Offline
Kiddart  Offline
K
yes I have one in my dart very nice radiator for the price.
Thank you
Kiddart
Re: jegs universal radiators [Re: n20mstr] #2662337
06/04/19 07:16 PM
06/04/19 07:16 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
.. I vote for ditch the fan get the smallest radiator possible and a tow vehicle..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: jegs universal radiators [Re: WHITEDART] #2662360
06/04/19 08:19 PM
06/04/19 08:19 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I have had two of them, one for the smallblock and one for the bigblock and both were well built and did a fine job. up
Re: jegs universal radiators [Re: dartman366] #2662415
06/04/19 10:14 PM
06/04/19 10:14 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I have the double row one inch tubes in a triple pass Afco with a spal fan.Total cost was $240
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: jegs universal radiators [Re: WHITEDART] #2662419
06/04/19 10:30 PM
06/04/19 10:30 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
Yea I know, I'm 3150 now, and that's 125lbs overweight for the class. I know adding a two row rad and I'll be close to 3200..... Wrong direction lol
Depending on where I park its 100 to 120 when I get in the lanes. Thankfully they are down hill so I don't have to fire it until it's at the water ready for a burnout. I've been making passes at 110 to 120 and get back to the trailer at 150-160
The rad in the car now is 11lbs and 1" but one row. The jegs rad is 1" but two row, and weighs 17 lbs. so prob 6lbs and 6. For another gallon of water capacity? Might run real cool for only 12-15lbs more. ?
Re: jegs universal radiators [Re: n20mstr] #2662420
06/04/19 10:31 PM
06/04/19 10:31 PM
Washington
skrews Offline
skrews  Offline
Washington
Had one in the car for years, worked great.
Re: jegs universal radiators [Re: hemi-itis] #2662421
06/04/19 10:39 PM
06/04/19 10:39 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
How cool does it run street driving ?
And how cool at the track ?
Re: jegs universal radiators [Re: ZIPPY] #2663250
06/06/19 08:52 PM
06/06/19 08:52 PM
middle Tennessee
mopower440 Offline
mopower440  Offline
middle Tennessee
I have not found this radiator on the summit site..Do you have a link?
Thanks!
Re: jegs universal radiators [Re: n20mstr] #2663289
06/06/19 10:42 PM
06/06/19 10:42 PM
hemi-itis Offline
hemi-itis  Offline
Cruise in 90* temp 185ish
Get in the water box @ 170ish and back at the pit is 185* grin
Re: jegs universal radiators [Re: hemi-itis] #2663364
06/07/19 08:08 AM
06/07/19 08:08 AM
N
n20mstr Offline OP
n20mstr  Offline OP
N
??? WHY SO HIGH? 170*
I had the fan in front as a pusher, im switching it to the back as a puller now.
Also im going to start taking the upper hose off and put some water thru the engine to get the temp down as much as possible.
I know guys using the water tank and they are going down the track at 70- 80*...However, the tank set up is heavy and needs tow up and back, unless its a HUGE tank and I cant afford any more weight !
