jegs universal radiators OR cooling tricks ?
#2662263
06/04/19 01:54 PM
06/04/19 01:54 PM
Posts: 4,673 On the parachute mount
n20mstr
Any one use one of these?
Right now I use a Mazda MPV radiator. And while its light, its just one row 1" is not really cutting it.
Its either buy a golf cart to tow up , or get a bigger rad. These Jegs are two row 1" so its basically double what I have now.
....BAD A$$ STREET CAR.....
Re: jegs universal radiators
[Re: n20mstr]
#2662298
06/04/19 04:27 PM
06/04/19 04:27 PM
KOS
I use a summit brand which is actually made by Northern has their name stamped right on it.....awsome piece 2row 1" around $150
[Re: KOS]
#2662330
06/04/19 06:58 PM
06/04/19 06:58 PM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
I use a summit brand which is actually made by Northern has their name stamped right on it.....awsome piece 2row 1" around $150 Me as well, a cross flow aluminum northern, for about the same price. It's been one of the better pieces on my car....
Rich H.
Esse Quam Videri
[Re: n20mstr]
#2662336
06/04/19 07:16 PM
06/04/19 07:16 PM
Posts: 1,548 Michigan
Kiddart
yes I have one in my dart very nice radiator for the price.
Thank you Kiddart
[Re: n20mstr]
#2662337
06/04/19 07:16 PM
06/04/19 07:16 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
.. I vote for ditch the fan get the smallest radiator possible and a tow vehicle..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: dartman366]
#2662415
06/04/19 10:14 PM
06/04/19 10:14 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I have the double row one inch tubes in a triple pass Afco with a spal fan.Total cost was $240
[Re: WHITEDART]
#2662419
06/04/19 10:30 PM
06/04/19 10:30 PM
n20mstr
.. I vote for ditch the fan get the smallest radiator possible and a tow vehicle.. Yea I know, I'm 3150 now, and that's 125lbs overweight for the class. I know adding a two row rad and I'll be close to 3200..... Wrong direction lol Depending on where I park its 100 to 120 when I get in the lanes. Thankfully they are down hill so I don't have to fire it until it's at the water ready for a burnout. I've been making passes at 110 to 120 and get back to the trailer at 150-160 The rad in the car now is 11lbs and 1" but one row. The jegs rad is 1" but two row, and weighs 17 lbs. so prob 6lbs and 6. For another gallon of water capacity? Might run real cool for only 12-15lbs more. ?
[Re: hemi-itis]
#2662421
06/04/19 10:39 PM
06/04/19 10:39 PM
n20mstr
I have the double row one inch tubes in a triple pass Afco with a spal fan.Total cost was $240 How cool does it run street driving ? And how cool at the track ?
[Re: ZIPPY]
#2663250
06/06/19 08:52 PM
06/06/19 08:52 PM
Posts: 2,863 middle Tennessee
mopower440
middle Tennessee
I use a summit brand which is actually made by Northern has their name stamped right on it.....awsome piece 2row 1" around $150 Me as well, a cross flow aluminum northern, for about the same price. It's been one of the better pieces on my car.... I have not found this radiator on the summit site..Do you have a link? Thanks!
[Re: n20mstr]
#2663289
06/06/19 10:42 PM
06/06/19 10:42 PM
hemi-itis
I have the double row one inch tubes in a triple pass Afco with a spal fan.Total cost was $240 How cool does it run street driving ? And how cool at the track ? Cruise in 90* temp 185ish Get in the water box @ 170ish and back at the pit is 185*
[Re: hemi-itis]
#2663364
06/07/19 08:08 AM
06/07/19 08:08 AM
n20mstr
I have the double row one inch tubes in a triple pass Afco with a spal fan.Total cost was $240 How cool does it run street driving ? And how cool at the track ? Cruise in 90* temp 185ish Get in the water box @ 170ish and back at the pit is 185* ??? WHY SO HIGH? 170* I had the fan in front as a pusher, im switching it to the back as a puller now. Also im going to start taking the upper hose off and put some water thru the engine to get the temp down as much as possible. I know guys using the water tank and they are going down the track at 70- 80*...However, the tank set up is heavy and needs tow up and back, unless its a HUGE tank and I cant afford any more weight !
