How much do you look at your tach when racing? #2661296
06/01/19 06:40 PM
06/01/19 06:40 PM
Wichita
GY3 Online content OP
GY3  Online Content OP
Wichita
I don't have one and shift by ear. The car seems fairly consistent this way. I recall an interview with Herb McCandless where he said he was too busy to look at a tach back in the day!
'63 Dodge 330
11.19 @ 121 mph
Re: How much do you look at your tach when racing? [Re: GY3] #2661306
06/01/19 07:01 PM
06/01/19 07:01 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I use a shift light
Re: How much do you look at your tach when racing? [Re: CSK] #2661316
06/01/19 07:31 PM
06/01/19 07:31 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
I look at the tach once in a while. Installed an air shifter this year....
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: How much do you look at your tach when racing? [Re: GY3] #2661325
06/01/19 08:14 PM
06/01/19 08:14 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
IMO its a distraction, but it is a good reference for training your ear for accuracy.
What do i know, I seldom win anyway. eek laugh2
Re: How much do you look at your tach when racing? [Re: jcc] #2661337
06/01/19 08:34 PM
06/01/19 08:34 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Drag car -
Pretty much in my line of sight, and I know the needle position without directly looking.
Plus a shift light in its face for further idiot-proofing.
I'll peek in the water (6000 max).
I rarely bother at the stripe, though, unless T&T.
Shutdown I'll glance at temp & oil PSI, but have another idiot light for oil PSI.
Road course car -
I'll glance on the straights at a gear change or two, along with temp & oil PSI, rest of the time it's the Zen method.
But yeah, with seat time you do learn to judge the sound.
Re: How much do you look at your tach when racing? [Re: GY3] #2661345
06/01/19 08:56 PM
06/01/19 08:56 PM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
I'm GY3's neighbor and can hear the car well over a mile away - I'm confident he has no problem hearing it red line penguin penguin
B Dartman's 71 Dart Swinger in Mopar Muscle (Sold Dec 2021): https://www.hotrod.com/articles/1971-dodge-dart-destiny-determination/
B Dartman's 71 Dart Swinger in Dodge Garage (Sold Dec 2021): https://www.dodgegarage.com/news/article/showcase/2019/04/destiny-determination.html
B Dartman's 71 Dart Swinger early build pictures (Sold Dec 2021): https://s165.photobucket.com/user/Billswild440dart/library/
Re: How much do you look at your tach when racing? [Re: B Dartman] #2661346
06/01/19 09:00 PM
06/01/19 09:00 PM
Wichita
Wichita
LMAO! Rev limiter is at 6400 for a reason....
Test and tune on Kellogg Avenue. drive
'63 Dodge 330
11.19 @ 121 mph
Re: How much do you look at your tach when racing? [Re: GY3] #2661384
06/01/19 11:20 PM
06/01/19 11:20 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I run a true footbrake class mostly, and I use the tach to stage the car. Also, I use it in the traps when I'm not too busy driving the finish line. I do use a air shifter that shifts low to second at a different RPM than second to high.
Brian
Re: How much do you look at your tach when racing? [Re: '72CudaRacer] #2661393
06/02/19 12:17 AM
06/02/19 12:17 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I tried looking at the tach in my car, but just put in a shift light and called it good.
I used to race a drag bike with no tach or shift light.
Re: How much do you look at your tach when racing? [Re: GY3] #2661401
06/02/19 03:02 AM
06/02/19 03:02 AM
Btween a rock and a hard place
moparlulu Offline
moparlulu  Offline
Naw, I just shift at valve float! Side note......Anyone have some good springs for sale???
Re: How much do you look at your tach when racing? [Re: CSK] #2661434
06/02/19 09:08 AM
06/02/19 09:08 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Originally Posted by csk
I use a shift light
iagree I do use it to stage when foot braking.
Re: How much do you look at your tach when racing? [Re: moparlulu] #2661436
06/02/19 09:10 AM
06/02/19 09:10 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I use the tach in the water box. The one time I tried using a launch limiter and line loc didn't work well (let's just say user error!) so ever since I've always staged off the tach, shift on the shift light and watch the tach over the stripe for reference.
Re: How much do you look at your tach when racing? [Re: GY3] #2661442
06/02/19 09:30 AM
06/02/19 09:30 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
5 times per pass. Burnout, staging, 1-2, 2-3 and stripe. Can't imagine creating a .020 or tighter package without one, or a rpm shifter or a shift light.
Re: How much do you look at your tach when racing? [Re: Leigh] #2661459
06/02/19 10:31 AM
06/02/19 10:31 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Staging, shifting, crossing the stripe. My tach actually reads a little higher than my EFI does(which drives the tach). So by the time I see 7000 on the tach and it goes through the low speed computer in my head to my hand it actually shifts at 7000RPM on the nose. I used to think I was mr awesome for hitting my shift points so fast when in fact my tach was leading me so I could make them on time lol.
68 Barracuda Formula S 340
Re: How much do you look at your tach when racing? [Re: Leigh] #2661477
06/02/19 11:14 AM
06/02/19 11:14 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Same here. I do rotate the tach where the shift RPM pointer is basically straight up. I also put a tape mark (like a second shift RPM pointer) at the RPM where I stage.
Re: How much do you look at your tach when racing? [Re: GY3] #2661499
06/02/19 11:51 AM
06/02/19 11:51 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I could not race without it.....Margins are too close these days to miss the launch rpm or a shift.....We are not allowed to use air to shift in our class.
Re: How much do you look at your tach when racing? [Re: Dragula] #2661594
06/02/19 05:11 PM
06/02/19 05:11 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I always shifted with a tach. Going to a shift light took a little getting used to. Still use the tach in the water. Defiantly use it to stage on the foot brake. Also nice to catch if the light malfunctions. I'd say every shift and starting line is usually within 50 rpm. For those of you that go "by ear". Maybe you shift early and you run a high torque motor that doesn't care. Or you miss it late slowing it down. I doubt it its very consistent. How do you stage? Bet it doesn't run back to back .00X second
Doug
Re: How much do you look at your tach when racing? [Re: dvw] #2661611
06/02/19 06:28 PM
06/02/19 06:28 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I use a shift light and look at the tach after the gear change to see if I'm driving through the clutch down track. I always watch it in the water and the stripe. When I had the 5-speed (3.27 low gear) in the car and 4.56 gears I shifted so fast into second it was hard to avert my eyes to the tach laugh2
Gus beer
64 Plymouth Savoy
Dana 60
Re: How much do you look at your tach when racing? [Re: GY3] #2661631
06/02/19 08:11 PM
06/02/19 08:11 PM
Windsor, ON, Canada
Diplomat360 Online content
Diplomat360  Online Content
Windsor, ON, Canada
I'm just a "baby" when it comes to the 1/4 mile stuff...seriously, probably at most 10-15 passes TOTAL...so the shift-light is a life-saver...seriously, when you do track as rarey as I do it just gets too busy when you're finally there, a shift-light lets me focus on feeling the car move off the starting line, engine revving and when the light goes off I bump the ratches shifter into the next gear.
Now from a street point of view I use the tach all the time..somehow it seems to be 2nd nature there...probably b/c we all spend so much time on the road as is, maybe it helps that my daily driver is a 5-spd car anyways and I always catch the tach there.
Re: How much do you look at your tach when racing? [Re: Diplomat360] #2661714
06/03/19 12:56 AM
06/03/19 12:56 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I never shift with the tach. I even tell myself to look at it and I just never do as I shift by the sound and feel of how the eng is pulling. I feel that I can tell when its peaking and when to shift. I will look at it going through the traps sometimes and sometimes on the starting line I look at it. But I basically have never shifted with the tach even when I bracket raced a 4-speed car and I was and still am very consisdent. Ron
