How much do you look at your tach when racing?
#2661296
06/01/19 06:40 PM
06/01/19 06:40 PM
Posts: 4,663 Wichita
GY3
Wichita
I don't have one and shift by ear. The car seems fairly consistent this way. I recall an interview with Herb McCandless where he said he was too busy to look at a tach back in the day!
Re: How much do you look at your tach when racing?
[Re: CSK]
#2661316
06/01/19 07:31 PM
06/01/19 07:31 PM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I look at the tach once in a while. Installed an air shifter this year....
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: B Dartman]
#2661346
06/01/19 09:00 PM
06/01/19 09:00 PM
GY3
Wichita
I don't have one and shift by ear. The car seems fairly consistent this way. I recall an interview with Herb McCandless where he said he was too busy to look at a tach back in the day! I'm GY3's neighbor and can hear the car well over a mile away - I'm confident he has no problem hearing it red line LMAO! Rev limiter is at 6400 for a reason.... Test and tune on Kellogg Avenue.
[Re: '72CudaRacer]
#2661393
06/02/19 12:17 AM
06/02/19 12:17 AM
Posts: 20,158 Park Forest, IL
slantzilla
Park Forest, IL
I tried looking at the tach in my car, but just put in a shift light and called it good.
I used to race a drag bike with no tach or shift light.
[Re: Leigh]
#2661459
06/02/19 10:31 AM
06/02/19 10:31 AM
Posts: 8,018 Tulsa OK
Bad340fish
Tulsa OK
Staging, shifting, crossing the stripe. My tach actually reads a little higher than my EFI does(which drives the tach). So by the time I see 7000 on the tach and it goes through the low speed computer in my head to my hand it actually shifts at 7000RPM on the nose. I used to think I was mr awesome for hitting my shift points so fast when in fact my tach was leading me so I could make them on time lol.
68 Barracuda Formula S 340
[Re: Leigh]
#2661477
06/02/19 11:14 AM
06/02/19 11:14 AM
BradH
5 times per pass. Burnout, staging, 1-2, 2-3 and stripe. Same here. I do rotate the tach where the shift RPM pointer is basically straight up. I also put a tape mark (like a second shift RPM pointer) at the RPM where I stage.
[Re: GY3]
#2661499
06/02/19 11:51 AM
06/02/19 11:51 AM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
I could not race without it.....Margins are too close these days to miss the launch rpm or a shift.....We are not allowed to use air to shift in our class.
[Re: GY3]
#2661631
06/02/19 08:11 PM
06/02/19 08:11 PM
Posts: 1,754 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
I'm just a "baby" when it comes to the 1/4 mile stuff...seriously, probably at most 10-15 passes TOTAL...so the shift-light is a life-saver...seriously, when you do track as rarey as I do it just gets too busy when you're finally there, a shift-light lets me focus on feeling the car move off the starting line, engine revving and when the light goes off I bump the ratches shifter into the next gear.
Now from a street point of view I use the tach all the time..somehow it seems to be 2nd nature there...probably b/c we all spend so much time on the road as is, maybe it helps that my daily driver is a 5-spd car anyways and I always catch the tach there.
