flex plate shield wont fit #2658244
05/22/19 11:01 PM
05/22/19 11:01 PM
ohio
dragon Offline OP
dragon  Offline OP
ohio
Got a power glide and can not get a flex shield to fit around the starter I have tried two different company's and they both will not fit I think they are made by the. Same company different name. But they are too long and hit the kick out for the starter. I do not have room between the frame.and trans even if you could bent it. not allow to cut it . any.other shields. Has anyone had this problem? Thanks
Re: flex plate shield wont fit [Re: dragon] #2658245
05/22/19 11:02 PM
05/22/19 11:02 PM
I'm assuming you are not using a adapter bell housing so you can use a stock Mopar starter, yes or no?
If yes call the flex shield company for help on this scope twocents
Re: flex plate shield wont fit [Re: dragon] #2658306
05/23/19 09:06 AM
05/23/19 09:06 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Car engine combo? Funny this “combo” has been around forever, but still has fitment issues here and there....
Re: flex plate shield wont fit [Re: J_BODY] #2658437
05/23/19 03:21 PM
05/23/19 03:21 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Stock case? Trim the extra junk off of the case. Look at a Reid or BTE. Make it look like that.
Re: flex plate shield wont fit [Re: CMcAllister] #2659293
05/26/19 09:54 AM
05/26/19 09:54 AM
ohio
dragon Offline OP
dragon  Offline OP
ohio
I called the peoples name on the shield they said they never had this problem. Well they checked it out and came back and said they tryed it on a stock case and it would not fit then was told I needed to cut the ears and flange that the dust cover mount to... I really did not want to do that so I called CSR talked to them they said there's would fit. Did not want to spend that kind of money but they had what would work. Thanks :
Re: flex plate shield wont fit [Re: dragon] #2659505
05/26/19 11:46 PM
05/26/19 11:46 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
shruggy
Re: flex plate shield wont fit [Re: CMcAllister] #2659516
05/27/19 01:24 AM
05/27/19 01:24 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Originally Posted by CMcAllister
shruggy
Guess when I hear “glide” I automatically think of aftermarket SFI cases.....
Re: flex plate shield wont fit [Re: J_BODY] #2659671
05/27/19 03:20 PM
05/27/19 03:20 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
An aftermarket case wouldn’t need an external shield. I just trim the stock case. Goes in better, headers fit better, shield fits. I don’t understand not wanting to do that. Everybody did it when they ran stock cases.
