Seat back position / angle #2658818
05/24/19 05:13 PM
05/24/19 05:13 PM
BDW Online content OP
BDW  Online Content OP
70 Challenger
How do you adjust the seat back position?
I read another thread and saw I didn’t have the correct HW. So I ordered the parts and installed it, but it feels like I’m sitting in a low rider ready for a drive-by it leans back so far.
Pic shows what was originally in there and put my seat in good position.
I tried adding washers to “correct” HW but running out of threads.
What am I doing wrong?
Re: Seat back position / angle [Re: BDW] #2658831
05/24/19 05:38 PM
05/24/19 05:38 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Your bump stop is upside down on the adjuster for starters. (narrow ring down is correct)
The typical way is to adjust the latch opposite the bump stop so it latches, then adjust the bump stop down until that meets the lower contact washer.
Do you have a photo of the seat in the car?
It may have a bent frame or broken weld.
Do you have the correct seat tracks?
Re: Seat back position / angle [Re: Alaskan_TA] #2658842
05/24/19 06:20 PM
05/24/19 06:20 PM
You’re probably on to something.
My seat has never latched. I don’t have to push the release to tilt the seat back forward.
I was under the impression this bumper set the tilt of the seat back.
So what can I check on the latch mechanism, or what does adjust the tilt?
Re: Seat back position / angle [Re: BDW] #2658848
05/24/19 06:25 PM
05/24/19 06:25 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The 'tilt' is not intended to be adjustable. (unless you have a manual 6-way seat adjuster, an extra cost option)
Which is why I asked for photos of what you have, something may be wrong.......
Re: Seat back position / angle [Re: Alaskan_TA] #2658849
05/24/19 06:29 PM
05/24/19 06:29 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
There was a factory recall letter issued for seats that did not latch - www.hamtramck-historical.com/images...folding%20seatback%20recall%20letter.jpg
But I have also seen bent frames & broken welds.
Re: Seat back position / angle [Re: Alaskan_TA] #2658854
05/24/19 06:48 PM
05/24/19 06:48 PM
Is it too late for me on that recall? smile
When I say tilt, I’m referring to the angle of the seat back.
Anyone have a pic of a disassembled seat to show how the latch mechanism should look/ work?
Would the seat cover have to come off to see what’s happening?
Re: Seat back position / angle [Re: BDW] #2659000
05/25/19 09:32 AM
05/25/19 09:32 AM
moparx Online content
moparx  Online Content
barry is right on the money about the bent and broken back frame situation. in every case i have seen with the "gangsta' lean" [i'm a poet 'n don't know it ! laugh2] , it was a bent or broken frame, or both. several times i have been able to fix them by skinning back a small section of the cover for the repair, but mostly, the cover has to come off.
also, if the frame is bent, it's a good idea [in my opinion] to reinforce the bent area to prevent it from bending again, forcing you to repeat the repair. after all, the assembly is 50 years old and has been through countless cycles in it's lifetime. the other option is to acquire another seat frame.
beer
