NE1 have an extra license plate bracket bolt? #2658502
05/23/19 06:13 PM
05/23/19 06:13 PM
GA
roadrunninMark Offline OP
GA
Don't know which section to put this in as it is on more than 1 body style, so putting it here in question and answer section. I am looking for 1 special bolt that a "fold down" license plate bracket has, the kind you flip down to access your gas tank. Mine is on a 69 road runner. The bolt has a flat round head and is usually connected (welded, glued?) to the bracket. Below are some pictures of what I am talking about. Anyone have an extra you don't need?
Thanks,
Mark
Re: NE1 have an extra license plate bracket bolt? [Re: roadrunninMark] #2658652
05/24/19 03:22 AM
05/24/19 03:22 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
They're usually inserted into sq.hole, then "staked" in at the opposite side. In a pinch you can get a carriage bolt to fit that sq opening & grind the oval portion of head flt. I did similar on a sway bkt.
Re: NE1 have an extra license plate bracket bolt? [Re: PhillyRag] #2658707
05/24/19 10:12 AM
05/24/19 10:12 AM
moparx Offline
moparx  Offline
also, there are "flat head" carriage bolts used in garage door hardware. you might check with your local hardware store.
if you have an ACE hardware available, their stores have an amazing selection of hardware useful in the automotive world.
beer
Re: NE1 have an extra license plate bracket bolt? [Re: moparx] #2658850
05/24/19 06:29 PM
05/24/19 06:29 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
I had to buy some of those flat garage door track bolts recently. ACE had them and they are cheap. up
Re: NE1 have an extra license plate bracket bolt? [Re: stumpy] #2659004
05/25/19 09:40 AM
05/25/19 09:40 AM
moparx Offline
moparx  Offline
like the commercial says stumpy, "ACE is the Place !" boogie biggrin
beer
Re: NE1 have an extra license plate bracket bolt? [Re: moparx] #2659019
05/25/19 10:09 AM
05/25/19 10:09 AM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
If you have a Fastenal store nearby they should have something that works and looks correct. They also ship stuff very reasonably, BTW.
Re: NE1 have an extra license plate bracket bolt? [Re: Powerflow] #2659033
05/25/19 10:29 AM
05/25/19 10:29 AM
moparx Offline
moparx  Offline
my local Fastenal store basically carries only a minimum of nuts and bolts, plus several other supplies in very minimal selections, and to order through the store, takes about four days. not saying all stores are like that though. yours is probably different.
i do know their catalog of fasteners is unbelievable ! up
beer
Re: NE1 have an extra license plate bracket bolt? [Re: moparx] #2659305
05/26/19 11:01 AM
05/26/19 11:01 AM
GA
GA
I have a fastenal not too far away, will check their online catalog. Local ACE was changed over to a private hardware store but they don’t have much in the way of bolts.
Thanks all for the input.
Re: NE1 have an extra license plate bracket bolt? [Re: roadrunninMark] #2659322
05/26/19 11:51 AM
05/26/19 11:51 AM
moparx Offline
moparx  Offline
that's too bad about your local ACE. the TruValue hardware a couple of towns over, changed to an ACE, and only used 2/3rds of the TrueValue store space. their hardware section is now THREE times [eek] the size of my ACE just a couple houses down from me.
it is unbelievable !
beer
Re: NE1 have an extra license plate bracket bolt? [Re: moparx] #2660977
05/31/19 03:12 PM
05/31/19 03:12 PM
GA
GA
Bolt received, thanks to Randy (1_WILD_RT)! boogie
