Magnum beer keg boost limit? #2658222
05/22/19 10:05 PM
05/22/19 10:05 PM
West Palm Beach, Florida
Craig J Online content OP
Craig J  Online Content OP
Does anyone use the magnum beer keg intake with boost? Assuming the stamped tin bottom plate is changed to a piece of 1/4" aluminum, I assume it should be ok up to 15 psi?
Craig
Re: Magnum beer keg boost limit? [Re: Craig J] #2658286
05/23/19 06:59 AM
05/23/19 06:59 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I would have the plate welded in place. Those intakes are known to move around, causing the gaskets to blow out under normal use.
