Lowered D150 Bump Stop #2658114
05/22/19 05:59 PM
05/22/19 05:59 PM
SE, Idaho
Spider Offline OP
Spider  Offline OP
SE, Idaho
For those that have lowered their 72-93 half-ton trucks, I am looking for pictures and ideas on what to do with the bump stop.
I know that people have cut the bump stop mount completely out, but I hate doing "permanent" mods.
Anyone ever try just removing the rubber bumper?
I am using van lower control arm.
73 Cuda 340
85 D100
2010 Procharged Road Glide
Re: Lowered D150 Bump Stop [Re: Spider] #2658121
05/22/19 06:07 PM
05/22/19 06:07 PM
Id
mopeman Offline
mopeman  Offline
Id
I cut mine down by half.
Mopar or no car
MoPar=Massivly Over Powered And Respected!
'93 W250 Ram
'68 Charger
'67 Coronet 500 my steet/strip rod-now a 6BBL!
Re: Lowered D150 Bump Stop [Re: mopeman] #2658124
05/22/19 06:14 PM
05/22/19 06:14 PM
SE, Idaho
Spider Offline OP
Spider  Offline OP
SE, Idaho
The mount or just the rubber?
73 Cuda 340
85 D100
Re: Lowered D150 Bump Stop [Re: Spider] #2658128
05/22/19 06:21 PM
05/22/19 06:21 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
When I lowered mine I just cut the rubber down.
Re: Lowered D150 Bump Stop [Re: Spider] #2658131
05/22/19 06:28 PM
05/22/19 06:28 PM
Id
mopeman Offline
mopeman  Offline
Id
The rubber bumper, that way I still had some cushion.
Mopar or no car
'93 W250 Ram
'68 Charger
Re: Lowered D150 Bump Stop [Re: stumpy] #2658132
05/22/19 06:28 PM
05/22/19 06:28 PM
SE, Idaho
Spider Offline OP
Spider  Offline OP
SE, Idaho
Cool! That's what I want to do. Does it hit often? Did you cut a couple inches?
73 Cuda 340
85 D100
Re: Lowered D150 Bump Stop [Re: Spider] #2658134
05/22/19 06:33 PM
05/22/19 06:33 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
That depends on how far you lowered it. I lowered mine 3" and cut the rubber by half.
Re: Lowered D150 Bump Stop [Re: stumpy] #2659530
05/27/19 06:59 AM
05/27/19 06:59 AM
,Pa.
68dodge Offline
68dodge  Offline
,Pa.
I cut the mount completely out, went with a 4" drop.
Re: Lowered D150 Bump Stop [Re: 68dodge] #2662390
06/04/19 09:23 PM
06/04/19 09:23 PM
Bay area, CA
Californian Offline
Californian  Offline
Bay area, CA
I've got my 76 lowered on van lower control arms and there is only 3/4" of space between the arm and the steel mount for the bump stop.
I know they are the original springs. How much gap should there be between the mount and the lower control arm?
1976 Dodge Californian 360, Thermoquad, 727 trans, 9.25 rear with 3.21 gears and a sure grip style rear.
