Re: Remote oil filter adapter for BB pump [Re: TRENDZ] #2656497
05/18/19 09:16 AM
05/18/19 09:16 AM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I will buy the Milodon 21255 cover.
Since this engine has the internal 1/2 (hemi) pickup, I will plug the suction port.
In the future, if I ever build a higher RPM engine and want a single line external line pickup, it can be used.
Re: Remote oil filter adapter for BB pump [Re: 440Jim] #2658021
05/22/19 02:03 PM
05/22/19 02:03 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Originally Posted by 440Jim
H The engine needs to go back about 1" and down about 3/4", but it hits the steering linkage.
And the reason it would not go back any further, was the lower frame mounts for the midplate were hitting the JW Mopar bellhousing on the PG transmission. I called the seller, and he cut notches in his JW bellhousing. I decided to just rotate the midplate frame mounts.
Re: Remote oil filter adapter for BB pump [Re: 440Jim] #2658025
05/22/19 02:08 PM
05/22/19 02:08 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I finished cutting off the old midplate mounts. Made new ones, and finished welding and painting them this morning.
Drilled new holes in midplate to match.
Re: Remote oil filter adapter for BB pump-solved! [Re: 440Jim] #2658751
05/24/19 12:12 PM
05/24/19 12:12 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
The Milodon oil pump cover worked great.
Plenty of clearance now!
Re: Remote oil filter adapter for BB pump-solved! [Re: 440Jim] #2658948
05/25/19 01:25 AM
05/25/19 01:25 AM
AndyF Online content
AndyF  Online Content
Looks nice and clean. You shouldn't have any issues with clearance for the lines or fittings. I'd use #12 lines but if you prefer #10 lines they should work okay as long as the runs aren't too long. Good luck, looks like you'll be racing pretty soon.
Re: Remote oil filter adapter for BB pump-solved! [Re: 440Jim] #2658972
05/25/19 07:07 AM
05/25/19 07:07 AM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
What pan did you use? Mine had the same issue.
Re: Remote oil filter adapter for BB pump-solved! [Re: DblOJoe] #2659877
05/28/19 08:45 AM
05/28/19 08:45 AM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I didn't build or design this engine. It was new and ready to go at the right price so I bought it. It has a center sump, 8qt steel pan with 1/2 internal oil pump pickup (hemi style).
Re: Remote oil filter adapter for BB pump-solved! [Re: 440Jim] #2659878
05/28/19 08:52 AM
05/28/19 08:52 AM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Joe,
What low mount alternator mount did you use?
I have a super mini Powermaster (93mm?), and your location looks good to me.
Re: Remote oil filter adapter for BB pump-solved! [Re: 440Jim] #2659933
05/28/19 11:06 AM
05/28/19 11:06 AM
Looks like he might have the DMI alternator bracket on there.
Re: Remote oil filter adapter for BB pump-solved! [Re: AndyF] #2660464
05/29/19 08:46 PM
05/29/19 08:46 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
Yep it's the DMI bracket. I'd get the brace with it if you get one it stiffens it up a bunch.
