HD BB rocker arm shafts w/o roller bearing rockers? #2657578
05/21/19 01:46 PM
05/21/19 01:46 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Who's making good thick-walled rocker arm shafts for BBs that use plain-bearing (not roller bearing fulcrum) rocker arms? These would be used w/ 600# open spring loads and need to be pretty stout to hold up during street & strip usage.
I know Harland Sharp shafts are beefy like the old RAS shafts. However, their oiling holes are drilled differently, so I don't know if that would cause problems w/ oiling at the bottom of the rockers, or if adding grooves would do the trick.
Speaking of RAS... anyone dealt with them now that they're back as Rocker Arms Unlimited? I'm almost scared to call them for price & availability of their shafts, considering how crappy their customer service and order filling time got before I guess the company changed owners or... ? They USED to have some pretty nice stuff, though.
Thanks - Brad
Re: HD BB rocker arm shafts w/o roller bearing rockers? [Re: BradH] #2657623
05/21/19 04:17 PM
05/21/19 04:17 PM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
Just bought Rockers from them. Didn't get their shafts because they were 3 weeks out minimum. So Im using Hughes Shafts. I spoke with Gary. Mike at B3 has the rockers now. Waiting on the heads to get back up to him. For geometry correction set up on my TF240s.
Re: HD BB rocker arm shafts w/o roller bearing rockers? [Re: HDNMOPERS] #2657662
05/21/19 05:50 PM
05/21/19 05:50 PM
BradH Offline OP
BradH  Offline OP
Originally Posted by HDNMOPERS
... Didn't get their shafts because they were 3 weeks out minimum.
Do you recall how much a pair of their shafts would cost?
Re: HD BB rocker arm shafts w/o roller bearing rockers? [Re: BradH] #2657666
05/21/19 06:14 PM
05/21/19 06:14 PM
AndyF Offline
AndyF  Offline
There was a set of RAS rocker arms for sale in the race section a few weeks back. It was a set that I used to own. I think the seller was asking $700 for them.
Re: HD BB rocker arm shafts w/o roller bearing rockers? [Re: AndyF] #2657721
05/21/19 07:49 PM
05/21/19 07:49 PM
BradH Offline OP
BradH  Offline OP
If I still used heads with standard-offset rockers, I'd have grabbed those when I first saw them listed. But, I don't, so I'm only looking into good options for new shafts.
Someone may be sending me a set of Hughes shafts to check out, but I don't think they're in the same league as the old RAS parts.
Re: HD BB rocker arm shafts w/o roller bearing rockers? [Re: BradH] #2657736
05/21/19 08:27 PM
05/21/19 08:27 PM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
I don't remember what the price was off hand. Once he said they were 3 weeks or so out. I said thats fine. Because I had a set Hughes shafts already. Dechellis Machine offers a .187 wall rocker shaft for the BB. Their stuff looks real nice.
Re: HD BB rocker arm shafts w/o roller bearing rockers? [Re: HDNMOPERS] #2657750
05/21/19 08:43 PM
05/21/19 08:43 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use Hughes shafts and hold downs. And I use the Hughes roller tip rockers. Been together since June 2011 and still going strong with no problems ever in the 8 years so far. And when I adjust my valves once a year they are never off much if at all. Ron
Re: HD BB rocker arm shafts w/o roller bearing rockers? [Re: BradH] #2657758
05/21/19 09:02 PM
05/21/19 09:02 PM
AndyF Offline
AndyF  Offline
Hughes used to buy their rocker shafts from RAS but I doubt they still do. That was a few years back........
Re: HD BB rocker arm shafts w/o roller bearing rockers? [Re: BradH] #2657793
05/21/19 10:45 PM
05/21/19 10:45 PM
New York
polyspheric Offline
polyspheric  Offline
New York
A shaft for a needle rocker (not a captive bearing with inner race) has to be in the Rockwell 50 numbers or it will brinnel itself to death, because the individual needle is knife-blade hard and its load per square inch of contact is MUCH higher than a plain bearing.
If you have a good bronze bushing in the rocker, and positive oil feed, the shaft can be much softer and cheaper to make. Except for the oil passages, it could be made from cored shelf stock (common fractional sizes) at a slight oversize and lathed to suit.
Boffin Emeritus
Re: HD BB rocker arm shafts w/o roller bearing rockers? [Re: HDNMOPERS] #2657951
05/22/19 11:24 AM
05/22/19 11:24 AM
BradH Offline OP
BradH  Offline OP
... Dechellis Machine offers a .187 wall rocker shaft for the BB. Their stuff looks real nice.
Can't find anything about them besides some high-dollar Hemi shafts & stands for alcohol funny car-type applications. Where did you see their BB shafts?
Re: HD BB rocker arm shafts w/o roller bearing rockers? [Re: AndyF] #2657953
05/22/19 11:25 AM
05/22/19 11:25 AM
BradH Offline OP
BradH  Offline OP
More than "a few", unfortunately.
Re: HD BB rocker arm shafts w/o roller bearing rockers? [Re: BradH] #2657969
05/22/19 11:46 AM
05/22/19 11:46 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I am using the Comp roller rockers with a liner on the shaft side and 440source HD shafts.....So far, 9.68 and no problems. A lot less chance of roller bearings going thru the engine if one fails. Had many 440source rocker bearings fail in our application over the years. 4 last year alone.
Re: HD BB rocker arm shafts w/o roller bearing rockers? [Re: BradH] #2657983
05/22/19 12:21 PM
05/22/19 12:21 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
I use nothing but Dechellis Machine rocker shafts on all of my builds. They make shafts for the top fuel boys and do have rocker shafts available for B/RB applications. Chrome plated hardened steel that are .187 thick. The best rocker shafts money can buy......
Re: HD BB rocker arm shafts w/o roller bearing rockers? [Re: ccdave] #2657986
05/22/19 12:36 PM
05/22/19 12:36 PM
BradH Offline OP
BradH  Offline OP
Pics? Price?
Re: HD BB rocker arm shafts w/o roller bearing rockers? [Re: BradH] #2657994
05/22/19 12:59 PM
05/22/19 12:59 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
What the consensus on these rocker arm kits that Mancini sells:
https://www.manciniracing.com/b16alrowibih.html
They are made by Harland Sharp for Mancini and cost $512 for the kit.
fast69plymouth said in a previous thread that they are close in length to the $908 set that Harland Sharp makes for use with Edelbrock (and Trickflow, Sidwinder, Promaxx) heads.
Re: HD BB rocker arm shafts w/o roller bearing rockers? [Re: BradH] #2657998
05/22/19 01:07 PM
05/22/19 01:07 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Originally Posted by BradH
Pics? Price?
ahhh....can't find alot, but:
http://www.dechellismachine.com/racingproducts.htm
No Wedge parts here
http://www.dechellismachine.com/Promo_11-07.pdf
Rich H.
Esse Quam Videri
Re: HD BB rocker arm shafts w/o roller bearing rockers? [Re: ZIPPY] #2658003
05/22/19 01:20 PM
05/22/19 01:20 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
Pics? Price?
No Wedge parts here
the pic on that flyer shows a shaft labelled "440" i'd guess the .187" shafts are $95 unhardened and $135 hardened. a phone call will say for sure...
Re: HD BB rocker arm shafts w/o roller bearing rockers? [Re: ZIPPY] #2658011
05/22/19 01:37 PM
05/22/19 01:37 PM
AndyF Offline
AndyF  Offline
The price sheet shows 440 shafts for $115.
Re: HD BB rocker arm shafts w/o roller bearing rockers? [Re: AndyF] #2658014
05/22/19 01:44 PM
05/22/19 01:44 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Missed that.
Rich H.
Esse Quam Videri
Re: HD BB rocker arm shafts w/o roller bearing rockers? [Re: AndyF] #2658015
05/22/19 01:50 PM
05/22/19 01:50 PM
BradH Offline OP
BradH  Offline OP
Yeah... 12 years ago. laugh2
Guess I'll have to callme 'em to get current info.
Thanks. up
