I am using the Comp roller rockers with a liner on the shaft side and 440source HD shafts.....So far, 9.68 and no problems. A lot less chance of roller bearings going thru the engine if one fails. Had many 440source rocker bearings fail in our application over the years. 4 last year alone.
