old school edelbrock torker intake #2651858
05/04/19 11:49 AM
05/04/19 11:49 AM
ontario canada kingston
aspenrt360 Offline OP
Hey guy's i have a few of the old type edelbrock torker intakes not the torker two. how are they i have never run one but i don't mind giving one a try for the price of some gaskets. i was thinking it may be not too bad with a spacer in an a body with a warmed over 360 with a comp 280 magnum cam true 10.5 to one compression 3500 flash on a lupo converter and 3.91 gears. not looking to win races just have some fun i have an ld 340 on there now but it has a plenum leak i have to get welded up and i want to hit an armdrop race in a couple of weeks. any thought from anyone who has one or ran one in the past?
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: old school edelbrock torker intake [Re: aspenrt360] #2651859
05/04/19 11:54 AM
05/04/19 11:54 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
If I had it sitting right there....... I’d try it.
Re: old school edelbrock torker intake [Re: fast68plymouth] #2651868
05/04/19 12:17 PM
05/04/19 12:17 PM
yeah i have a few i have collected over the years i never ran one though so i don't know if they are turds or not?
Re: old school edelbrock torker intake [Re: aspenrt360] #2651872
05/04/19 12:21 PM
05/04/19 12:21 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I'd never spend money on one as I doubt they are any better than a stock intake but if you have one it wouldn't hurt to try it.
Sheldon
Re: old school edelbrock torker intake [Re: aspenrt360] #2651930
05/04/19 03:56 PM
05/04/19 03:56 PM
I used a 340 Torker intake on a 1968 340 motor that went into a 1965 Baracuda that didn't perform well but the owner used the stock 273 exhaust manifolds with the stock single exhaust system instead of buying a good set of headers like I told him that motor needed shruggy
All motor need to breathe to perform well up The single plane intake compared to a decent dual plane will depend on the cam, converter, rear gear and owners likes and dislike on how they like that intake work twocents
Re: old school edelbrock torker intake [Re: Cab_Burge] #2651935
05/04/19 04:06 PM
05/04/19 04:06 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Back in the day, I used it on both my 340 cars.
Ran a best of 11.98 They were the best at that time.
I'd try it if I had one again.
It wasnt a slug by any means..
Re: old school edelbrock torker intake [Re: Sammy] #2651991
05/04/19 07:30 PM
05/04/19 07:30 PM
Thanks guys i think i will give it a go what the heck all it takes is a bit of time and some gaskets. i have heard everything form it sucks to it was not bad back in the day, i am not expecting modern intake performance but it is a single plane so with my converter and gears in a fairly light street car it should work ok. i have no rpm worries so i will report back once i get it on the engine and let you know back to back what it runs like from the LD340 to the Torker340 should be sometime late next week.
Re: old school edelbrock torker intake [Re: aspenrt360] #2652047
05/04/19 11:44 PM
05/04/19 11:44 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
They were ok for their time. Back around 2001 when I had the mild 383 in my Dart it had run 12.49 @ 109 with the old Torker. I put the Performer RPM on later and it ran 12.31 @ 110. The RPM was just much better in the 60 ft and 1/8 mile but for how old the Torker is it is not that bad. I believe in a intake test by Mopar Muscle about 10 or so years back the old Torker actually pulled more torque then any other intake they tested on a 440. Not the best hp as a few were better in hp but it had the top torque #. Ron
Re: old school edelbrock torker intake [Re: aspenrt360] #2652102
05/05/19 08:29 AM
05/05/19 08:29 AM
Holland MI Ottawa
2
2boltmain Online content
2boltmain  Online Content
Holland MI Ottawa
You have the recommended compression stall and gear for the old Torker single plane design. Should run very well.
Keep old mopars alive.
Re: old school edelbrock torker intake [Re: 2boltmain] #2653790
05/09/19 06:10 PM
05/09/19 06:10 PM
ok so i popped it on with a 1 inch open spacer and it is good in fact it is very good! with the converter i have it is roughly the same out of the hole but from mid range on it out pulls the LD340 by a fair bit i will have it on the track in two weeks to get some slips both intakes are stock with just mild port matching to the ported heads. i am going to put an Eddy air gap on later in the summer as i have one coming back to me and i want to try and find a more modern single plane to try out as well but the Torker 340 intake is not junk at all i think many guys just don't have the right combo to run it.
Re: old school edelbrock torker intake [Re: aspenrt360] #2653840
05/09/19 09:25 PM
05/09/19 09:25 PM
n.c.
geo. Offline
geo.  Offline
n.c.
Back in the mid '80s there was a very strong running '66-7 Satellite.
340, Xheads, headers, big cam, 4 speed, 4.56 gear, cragars (of course) and a torker.
Of course street racers seldom went a full 1/4 mile, but it sure pulled!
Re: old school edelbrock torker intake [Re: RUNCHARGER] #2653892
05/10/19 01:38 AM
05/10/19 01:38 AM
PA
Scully Offline
Scully  Offline
PA
It's about 3 tenths quicker than a stock intake.
Re: old school edelbrock torker intake [Re: aspenrt360] #2654105
05/10/19 06:20 PM
05/10/19 06:20 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Since like you I have assembled a bit of SB intake collection over the years, and I still have my pics up on the web server, why not share right?
Here they are, some intake comparisons, order is: LD340, PerformerPRM, Torker2, Strip Dominator:
Re: old school edelbrock torker intake [Re: Diplomat360] #2654124
05/10/19 07:08 PM
05/10/19 07:08 PM
wow the torker 2 has a ton more plenum volume than the torker does the 1 inch spacer must be helping it a fair bit. it works pretty good but i can see where if you don't have enough converter and gear it would be a dog!
Re: old school edelbrock torker intake [Re: aspenrt360] #2654164
05/10/19 09:06 PM
05/10/19 09:06 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Yeah, I found that the intake tech moved to the runners with higher AOA - Angle Of Approach, idea being that this allows the mixture to be more directed towards the valve bowl and valve head, sort of more of a ramming effect as opposed to travelling flat and having to make that "giant" turn towards the cylinder.
Here is couple of pics of direct plenum volumes:
Re: old school edelbrock torker intake [Re: Diplomat360] #2655155
05/13/19 09:15 PM
05/13/19 09:15 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
You can't bolt a torker on a stock engine and expect magic.
Paired with a .500ish cam, 750 carb and 10.5 compression and its one of the best.
I've swapped back to back M1, Torker and TM7 on my 383.
I like the TM7 best but they are all within a tenth.
The NHRA sportsman world champ runs a 340 with a torker.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: old school edelbrock torker intake [Re: 69dart] #2656664
05/18/19 07:34 PM
05/18/19 07:34 PM
So we ran this intake today and it was really good! it was an armdrop event at an old WW2 airfield that is just as it was back in the 40's cool place no grip but really fun and a great place to have my wife make her first passes down the strip ever! it pulled just fine and had a good top end charge all in all i am happy. next friday i am taking the car to an actual track and i will have some slips to get data from.
Re: old school edelbrock torker intake [Re: aspenrt360] #2656721
05/18/19 11:15 PM
05/18/19 11:15 PM
Any day at the track or something near a track that you and the wife had fun and came home happy is a VERY GOOD Day up bow up
Re: old school edelbrock torker intake [Re: Cab_Burge] #2656777
05/19/19 09:40 AM
05/19/19 09:40 AM
100% this car sat under a tarp for 27 years it is solid but not very pretty anymore we plan on running it for a season or two then restore. i pulled the #'s engine and trans and popped in a warm 360 and fresh 727 i had kicking around so we could enjoy the car a bit while i finish some customer work and a Swinger i am doing some metal work on, so far the car has been a joy to drive and the wife was all smiles after her first couple of passes!
Re: old school edelbrock torker intake [Re: aspenrt360] #2658882
05/24/19 08:25 PM
05/24/19 08:25 PM
OK not the best trip to the track! this is a street car so we drive it to the track which is a good 45 min trip if we take the big hwy but with 3.91's it likes it's fuel! so we get there my first pass with drag radials not sure how low to go with psi on the tires so i start with 24 and roast them right through first gear! 2.302 60 foot! LOL! 14.43 1/4 at 96.62 mph next pass drop the air to 18 psi still get some spin but better i think i need to do a longer burnout 1.928 60 foot as i am shifting to second i notice my alt gauge is flat out pegged so i lift pull into pits it is fubar i pull the wires off of the alt to not boil the battery. now i have to limp home with no alt on the battery before it gets dark and i need the headlights! i will go back in two weeks and try to get it dialed in. it feels like a mid to high 13 second car with the torker and fairly small cam should be just right for my wife to have fun.
