BB Valve Covers that work with an MSD Distributor
#2656682
05/18/19 08:36 PM
05/18/19 08:36 PM
Posts: 304 Portland, Oregon
Digger73
Portland, Oregon
I have searched the site and have not found an answer for what I need. I have Trickflow 270 heads on an RB with Crane roller rockers and run a Pro billet MSD distributor. What I need now is valve covers that will work with this combination. What have you guys run that works? Pictures would be awesome. I would hate to carve on the distributor? Why didn't MSD make the distributor body 1" to 2" taller? Thanks in advance, Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: BB Valve Covers that work with an MSD Distributor
[Re: AndyF]
#2656687
05/18/19 09:21 PM
05/18/19 09:21 PM
Digger73
Portland, Oregon
Thanks for the picture Andy. Your distributor is higher on the valve cover than mine. On mine the surface that the cap sits on is level with the outer lip of the valve cover. It seems that the heads have a taller valve cover surface. My heads are the max wedge ports if that makes a difference?
Digger73 (Mike)
[Re: Digger73]
#2656692
05/18/19 09:36 PM
05/18/19 09:36 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
I have Indy style cast aluminum valve covers and did need to grind the corner so the msd pro billet will fit. Not a big deal for me since you can’t see it on the engine, and it only took a few minutes. I definitely would not do any grinding on the distributor.
2 kids and a dog
[Re: TonyS451]
#2656695
05/18/19 09:45 PM
05/18/19 09:45 PM
Digger73
Portland, Oregon
I have Indy style cast aluminum valve covers and did need to grind the corner so the msd pro billet will fit. Not a big deal for me since you can’t see it on the engine, and it only took a few minutes. I definitely would not do any grinding on the distributor. Any pictures? Digger73 (Mike)
[Re: Cab_Burge]
#2656743
05/19/19 04:33 AM
05/19/19 04:33 AM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
I run the 270 head and Mopar cast covers with msd distributor . Had to grind cover and distributor
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2656845
05/19/19 12:07 PM
05/19/19 12:07 PM
Digger73
Portland, Oregon
Thanks for all the answers. Has anyone used this combination with the Trick Flow valve covers? They seem to have the relief cast into them already.
Digger73 (Mike)
