BB Valve Covers that work with an MSD Distributor #2656682
05/18/19 08:36 PM
05/18/19 08:36 PM
Portland, Oregon
Digger73 Offline OP
Digger73  Offline OP
Portland, Oregon
I have searched the site and have not found an answer for what I need.
I have Trickflow 270 heads on an RB with Crane roller rockers and run a Pro billet MSD distributor.
What I need now is valve covers that will work with this combination.
What have you guys run that works?
Pictures would be awesome.
I would hate to carve on the distributor?
Why didn't MSD make the distributor body 1" to 2" taller?
Thanks in advance,
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: BB Valve Covers that work with an MSD Distributor [Re: Digger73] #2656683
05/18/19 08:56 PM
05/18/19 08:56 PM
AndyF Offline
AndyF  Offline
I think most valve covers will fit after a little grinding on the valve cover lip.
Re: BB Valve Covers that work with an MSD Distributor [Re: AndyF] #2656687
05/18/19 09:21 PM
05/18/19 09:21 PM
Portland, Oregon
Digger73 Offline OP
Digger73  Offline OP
Portland, Oregon
Thanks for the picture Andy.
Your distributor is higher on the valve cover than mine.
On mine the surface that the cap sits on is level with the outer lip of the valve cover.
It seems that the heads have a taller valve cover surface.
My heads are the max wedge ports if that makes a difference?
Digger73 (Mike)
Re: BB Valve Covers that work with an MSD Distributor [Re: Digger73] #2656692
05/18/19 09:36 PM
05/18/19 09:36 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
I have Indy style cast aluminum valve covers and did need to grind the corner so the msd pro billet will fit. Not a big deal for me since you can’t see it on the engine, and it only took a few minutes. I definitely would not do any grinding on the distributor.
2 kids and a dog
Re: BB Valve Covers that work with an MSD Distributor [Re: TonyS451] #2656695
05/18/19 09:45 PM
05/18/19 09:45 PM
Portland, Oregon
Digger73 Offline OP
Digger73  Offline OP
Portland, Oregon
Any pictures?
Digger73 (Mike)
Re: BB Valve Covers that work with an MSD Distributor [Re: Digger73] #2656720
05/18/19 11:15 PM
05/18/19 11:15 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
I use cast Indy covers...no grinding needed for these.
sorry....wrong heads
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: BB Valve Covers that work with an MSD Distributor [Re: Digger73] #2656722
05/18/19 11:17 PM
05/18/19 11:17 PM
I've had to grind on more than one set of cast aluminum valve covers due to running one of them dang MSD billet distributers wrench shruggy
Re: BB Valve Covers that work with an MSD Distributor [Re: Cab_Burge] #2656743
05/19/19 04:33 AM
05/19/19 04:33 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I run the 270 head and Mopar cast covers with msd distributor . Had to grind cover and distributor
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: BB Valve Covers that work with an MSD Distributor [Re: tex013] #2656845
05/19/19 12:07 PM
05/19/19 12:07 PM
Portland, Oregon
Digger73 Offline OP
Digger73  Offline OP
Portland, Oregon
Thanks for all the answers.
Has anyone used this combination with the Trick Flow valve covers?
They seem to have the relief cast into them already.
Digger73 (Mike)
