Remote oil filter adapter for BB pump-solved! #2656133
05/16/19 09:52 PM
05/16/19 09:52 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I found a surprise on the Daytona I bought.
The stock oil pump hits the steering linkage, where the filter mounts to the pump.
The stock unit is too wide at the filter boss. The pump itself clears fine, past the universal joint.
Does anyone make an oil pump cover to use a remote filter mount, but doesn't use the circle of the stock filter/mount?
I would prefer to not change the entire engine over to an external pickup system and pan.
The engine is built, dyno tested, and ready to race. And it doesn't turn over 6000ish RPM.
Re: Remote oil filter adapter for BB pump [Re: 440Jim] #2656135
05/16/19 09:55 PM
05/16/19 09:55 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Here is the view from the side. The engine needs to go back about 1" and down about 3/4", but it hits the steering linkage.
Re: Remote oil filter adapter for BB pump [Re: 440Jim] #2656141
05/16/19 10:25 PM
05/16/19 10:25 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
440Source makes an awesome unit AND the price is right !!
Well I just checked their website and it looks like they no longer have them BUT if it were me, I'd give them a call - you never know, they may have a couple left.
Re: Remote oil filter adapter for BB pump [Re: Stanton] #2656144
05/16/19 10:41 PM
05/16/19 10:41 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Milodon make one from memory
Alan Jones
Re: Remote oil filter adapter for BB pump [Re: 440Jim] #2656146
05/16/19 10:42 PM
05/16/19 10:42 PM
AndyF Offline
AndyF  Offline
I made this cover a few years back. It might work for you. The lines point straight down out of the cover so you'll have to look to see if the fittings would clear your steering. The other option is to use the Milodon 21225 which routes the oil lines out the front of the block. That cover would clear your system but you'll need to invest in a remote filter. I have a CV housing sitting on the shelf if you're interested. I sold off the last of my Milodon stash last year otherwise I would've had everything you needed.
Re: Remote oil filter adapter for BB pump [Re: 440Jim] #2656151
05/16/19 11:09 PM
05/16/19 11:09 PM
I use the Milidon pump cover that is set up for using fittings and hoses to the remote HP6 type oil filter up scope
I wish I knew how to post pictures on here so I could show you mine in my tube chassis car with steering like yours whiney
Let us know what you do thumbs
Re: Remote oil filter adapter for BB pump [Re: Cab_Burge] #2656154
05/16/19 11:27 PM
05/16/19 11:27 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I removed an accusump and a dual remote oil filter set and replaced it with a system one oil filter.Wish I did it years sooner but we all know how that goes.Andy has a cover so it would be a snap.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Remote oil filter adapter for BB pump [Re: hemi-itis] #2656174
05/17/19 03:52 AM
05/17/19 03:52 AM
Finland
Hessu Offline
Hessu  Offline
Finland
Re: Remote oil filter adapter for BB pump [Re: Hessu] #2656179
05/17/19 06:48 AM
05/17/19 06:48 AM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I am using the internal oil pickup.
I only need to have the fittings on the pump for the remote filter.
These pump covers that include both the remote filter fittings, and the external oil pickup lines, can I just plug the pickup line holes?
Will they then work with the internal oil pickup passages (stock/hemi)?
For example, the Milidon-21225
[img]https://static.summitracing.com/global/images/prod/mediumlarge/mil-21225_ml.jpg?rep=False[/img]
Re: Remote oil filter adapter for BB pump [Re: 440Jim] #2656180
05/17/19 06:55 AM
05/17/19 06:55 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
There shouldn't be any issues if you wanted to plug off the external pickup line and just use your existing internal setup, as long as you use the same pump. Some of the race pumps don't have holes drilled for internal pickup.
Re: Remote oil filter adapter for BB pump [Re: sgcuda] #2656226
05/17/19 10:41 AM
05/17/19 10:41 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I've never had a chassis car that didn't have the same interference. All you are going to change is the top cover. There are several on the market. The billet aluminum Milodon as already shown is a nice one.
2011 Drag Pak Challenger
Re: Remote oil filter adapter for BB pump [Re: rickseeman] #2656233
05/17/19 11:27 AM
05/17/19 11:27 AM
Rochester, PA (near Pittsburgh...
1974 474 Duster Offline
I have the same issue on my Daytona. I use a NAPA Gold 1311 short filter on it. Shouldn't see much debris & let's face it. You can always change the filter & add 1/2qt of oil
See ya, Ken
Re: Remote oil filter adapter for BB pump [Re: 440Jim] #2656235
05/17/19 11:29 AM
05/17/19 11:29 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I have never owned a 21225, but I bought the 21215 and remember it had provisions for both internal and external pickup,
and either port could have been blocked off to run the other.
Since it's kind of the same family of parts, I would be surprised if the 21225 was not the same.
Rich H.
Esse Quam Videri
Re: Remote oil filter adapter for BB pump [Re: 440Jim] #2656247
05/17/19 12:06 PM
05/17/19 12:06 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
This would probably work but I can't remember who made it.
Re: Remote oil filter adapter for BB pump [Re: John_Kunkel] #2656251
05/17/19 12:40 PM
05/17/19 12:40 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Don’t hold me to it but I think Canton offers some nice stuff.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Remote oil filter adapter for BB pump [Re: 440Jim] #2656269
05/17/19 01:28 PM
05/17/19 01:28 PM
PA.
"Little"John
"Little"John
PA.
I haven’t finished the oiling system on my head up car but it’s real tight in the oil pump area too
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Remote oil filter adapter for BB pump [Re: 440Jim] #2656274
05/17/19 01:48 PM
05/17/19 01:48 PM
southern Maryland
K
keefe Offline
keefe  Offline
K
southern Maryland
Hi Jim how are ya ,Nice Daytona.
I saved this article a while back , it might have what your looking for.
Its a 505 build that used a external pump / filter system , the articles was done in 2010
so hopefully the pump parts are available.
https://www.americanmusclecarsaustralia.com/forum/index.php?topic=3526.0
1971 duster twister 440, 3380#,509 M/P hyd,906's,full Exhaust,11.06@117.46 1/4,6.95@ 97.03 1/8,1.497 60ft.....
Re: Remote oil filter adapter for BB pump [Re: keefe] #2656277
05/17/19 02:00 PM
05/17/19 02:00 PM
AndyF Offline
AndyF  Offline
That is my old 505
Re: Remote oil filter adapter for BB pump [Re: hemi-itis] #2656289
05/17/19 02:52 PM
05/17/19 02:52 PM
hemi-itis Offline
hemi-itis  Offline
Originally Posted by hemi-itis
I removed an accusump and a dual remote oil filter set up to a system and replaced it with a system one oil filter.Wish I did it years sooner but we all know how that goes.Andy has a cover so it would be a snap.
2 short hoses from the pump to the filter up
Re: Remote oil filter adapter for BB pump [Re: 440Jim] #2656336
05/17/19 05:14 PM
05/17/19 05:14 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
As mentioned earlier, the milodon cover would be a direct bolt on. All your clearance issues would be gone with that cover. You don’t need to use that cover as an external feed.
