Custom Cam #2654963
05/13/19 12:46 PM
05/13/19 12:46 PM
New Braunfels, TX
416challenger Offline OP
New Braunfels, TX
I picked up a 5.7 recently and wondering who are the cam experts for custom ground cams for the gen 3 hemis? Who are you guys using?
Re: Custom Cam [Re: 416challenger] #2655293
05/14/19 10:41 AM
05/14/19 10:41 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Why do you think you will need a custom camshaft?
I think for a start I would contact someone like this for a recommendation for an off the shelf camshaft and supporting hardware if needed:
Modern Muscle Performance
340 Colonel Lee Road
Martinsville, VA 24112
Phone: 276-666-1934
Please use the email address below for sales and technical questions!
E-Mail: info@modernmuscleperformance.com
Hours of Operations (Eastern Standard Time):
Monday: 8:00 AM to 5:00 PM
Tuesday: 8:00 AM to 5:00 PM
Wednesday: 8:00 AM to 5:00 PM
Thursday: 8:00 AM to 5:00 PM
Friday: 8:00 AM to 5:00 PM
Saturday: By Appointment Only
Sunday: Closed
Re: Custom Cam [Re: 340Cuda] #2655333
05/14/19 12:51 PM
05/14/19 12:51 PM
New Braunfels, TX
New Braunfels, TX
340Cuda- I just figured there is some power to gain with a custom cam over a shelf cam. Most of the shelf cams are designed for the new Challengers, Chargers, etc. (Heavy cars with not a lot gear or converter). I plan to put the 5.7 in my 73 Challenger with 4800 stall, 4.10 gear, single plane intake (Ritter or Cascar), big headers.
Re: Custom Cam [Re: 416challenger] #2655365
05/14/19 02:03 PM
05/14/19 02:03 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
You could be right, but Dave Weber's company above would still be a good place to start.
Good luck with your project and keep us posted on your progress.
Re: Custom Cam [Re: 416challenger] #2655402
05/14/19 03:34 PM
05/14/19 03:34 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I got my custom cam(Comp Cams) from Ray(sixpackgut) when he worked on my heads. Same cost as a shelf cam.
One stop shopping.
Re: Custom Cam [Re: RTSE4ME] #2655627
05/15/19 09:21 AM
05/15/19 09:21 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
One stop shopping.
I think of Ray for heads and manifolds but he would also be a great resource on camshafts as well.
https://www.facebook.com/BornAgainHotRods/
Re: Custom Cam [Re: 340Cuda] #2655753
05/15/19 05:17 PM
05/15/19 05:17 PM
Australia
L4staero Offline
L4staero  Offline
Australia
Erik at BFNY performance also has a lot of experience specing custom cams on G3's.
Imo MMX just keep regurging the same profiles. Most of the time they rec their MMX no spring required cam which is just a Comp 270 off the shelf intake lobe with a slower LS exhaust lobe and slight lsa change. They promote a stg 3 and stg 4 lope cam with only difference is 1 deg lsa
Re: Custom Cam [Re: L4staero] #2656453
05/18/19 12:57 AM
05/18/19 12:57 AM
Australia
L4staero Offline
L4staero  Offline
Australia
These are the lobes from the MMX NSR cams
Int-13183 lobe xtreme energy VVI Ex-3718 lobe-extreme rpm ls1
A very good option is Comp cams LSL lobes. These are designed for G3's and LS1's and have a range from 211-275@.050" to choose from with lift still within the capability of stock rockers
Re: Custom Cam [Re: 340Cuda] #2656651
05/18/19 05:51 PM
05/18/19 05:51 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
One stop shopping.
If Im porting someone's heads for g3 stuff, I want the springs setup for the cam so I use Steve Frank for a cam and don't make a dollar on the cam and have it shipped direct to customer. For the LS crowd I only do that for the guy's I know will know better if they change cams the spring setup must change. And the list for those guys is somewhat short.
Re: Custom Cam [Re: sixpackgut] #2656765
05/19/19 09:06 AM
05/19/19 09:06 AM
New Braunfels, TX
New Braunfels, TX
Thanks for the recommendations. I sent out a emails to a few of the recommended. Thank.
