Re: Custom Cam
[Re: L4staero]
#2656453
05/18/19 12:57 AM
05/18/19 12:57 AM
Posts: 146 Australia
L4staero
Australia
These are the lobes from the MMX NSR cams Int-13183 lobe xtreme energy VVI Ex-3718 lobe-extreme rpm ls1
A very good option is Comp cams LSL lobes. These are designed for G3's and LS1's and have a range from 211-275@.050" to choose from with lift still within the capability of stock rockers
Re: Custom Cam
[Re: 340Cuda]
#2656651
05/18/19 05:51 PM
05/18/19 05:51 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I got my custom cam(Comp Cams) from Ray(sixpackgut) when he worked on my heads. Same cost as a shelf cam. One stop shopping. I think of Ray for heads and manifolds but he would also be a great resource on camshafts as well. https://www.facebook.com/BornAgainHotRods/ If Im porting someone's heads for g3 stuff, I want the springs setup for the cam so I use Steve Frank for a cam and don't make a dollar on the cam and have it shipped direct to customer. For the LS crowd I only do that for the guy's I know will know better if they change cams the spring setup must change. And the list for those guys is somewhat short.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
