Radiator sizing #2654754
05/12/19 08:39 PM
05/12/19 08:39 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
As it stand at the moment we are going to use a 360 magnum in my sons 72 cuda. The car is a non air car but going to install vintage air. The car has a 22" opening. Will that size radiator handle a built 360 with A/C ?? If we decided to go Gen 3 will a 22" rad work? What radiator is everyone using? It's on the rotisserie now , so if i need to make the change better do it now. but if i dont have to i wont. Thoughts??
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: Radiator sizing [Re: hulmule] #2654790
05/12/19 10:11 PM
05/12/19 10:11 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
With A/C I would fix the car for a 26" rad
Re: Radiator sizing [Re: CSK] #2654816
05/12/19 11:13 PM
05/12/19 11:13 PM
Washington
madscientist Offline
Washington
^^^^^^^^^^^^This^^^^^^^^^^^ and I would use a high volume pump, turn the pump at least 6% over cranks speed and get a big two core radiator. The bigger the core the better. 1.25 cores are as small as I'd go, and if you can find 1.5 cores get that.
Re: Radiator sizing [Re: madscientist] #2655032
05/13/19 04:13 PM
05/13/19 04:13 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
This one will cool a bunch better than a stock , or a stock style radiator.
No cooler for the trans , but it should be a bolt in fit.
https://www.jegs.com/i/Griffin-Radiators/475/8-00038/10002/-1
Re: Radiator sizing [Re: tubtar] #2655543
05/14/19 09:47 PM
05/14/19 09:47 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
This is the one I'm going with this year http://www.speedcooling.com/26-Big-Block-Mopar-Radiator.html
Gus beer
64 Plymouth Savoy
Dana 60
Re: Radiator sizing [Re: fourgearsavoy] #2655546
05/14/19 09:54 PM
05/14/19 09:54 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Gus beer
That is the one I run in my Charger, 512 cid,COLD ac, south Texas heat, runs 180ish all day long
Re: Radiator sizing [Re: fourgearsavoy] #2655547
05/14/19 09:55 PM
05/14/19 09:55 PM
Washington
Washington
Gus beer
Look very close at the drawings. That's the radiator I bought and the claim is its a drop in fit. It's not. While the drawing looks correct, the X-Y-Z zero is off or something. And the radiator won't fit in the stock bolt locations. This was far a 73 A body.
The radiator cools like jack the bear, it just didn't as a bolt in replacement.
If I had to do it over (and I may) I'd buy a Cold Case radiator because I've seen one of those and it bolts in directly.
