Radiator sizing
#2654754
05/12/19 08:39 PM
05/12/19 08:39 PM
Posts: 1,412 northeast ohio
hulmule
northeast ohio
As it stand at the moment we are going to use a 360 magnum in my sons 72 cuda. The car is a non air car but going to install vintage air. The car has a 22" opening. Will that size radiator handle a built 360 with A/C ?? If we decided to go Gen 3 will a 22" rad work? What radiator is everyone using? It's on the rotisserie now , so if i need to make the change better do it now. but if i dont have to i wont. Thoughts??
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
Re: Radiator sizing
[Re: hulmule]
#2654790
05/12/19 10:11 PM
05/12/19 10:11 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
With A/C I would fix the car for a 26" rad
Re: Radiator sizing
[Re: CSK]
#2654816
05/12/19 11:13 PM
05/12/19 11:13 PM
Posts: 4,457 Washington
madscientist
Washington
With A/C I would fix the car for a 26" rad ^^^^^^^^^^^^This^^^^^^^^^^^ and I would use a high volume pump, turn the pump at least 6% over cranks speed and get a big two core radiator. The bigger the core the better. 1.25 cores are as small as I'd go, and if you can find 1.5 cores get that.
Re: Radiator sizing
[Re: fourgearsavoy]
#2655546
05/14/19 09:54 PM
05/14/19 09:54 PM
CSK
Pattison Texas
That is the one I run in my Charger, 512 cid,COLD ac, south Texas heat, runs 180ish all day long
Re: Radiator sizing
[Re: fourgearsavoy]
#2655547
05/14/19 09:55 PM
05/14/19 09:55 PM
madscientist
Washington
Look very close at the drawings. That's the radiator I bought and the claim is its a drop in fit. It's not. While the drawing looks correct, the X-Y-Z zero is off or something. And the radiator won't fit in the stock bolt locations. This was far a 73 A body. The radiator cools like jack the bear, it just didn't as a bolt in replacement. If I had to do it over (and I may) I'd buy a Cold Case radiator because I've seen one of those and it bolts in directly.
