cruise control turn signal switch #2654722
05/12/19 07:08 PM
05/12/19 07:08 PM
Carlisle, AR.
mdwyer Offline OP
mdwyer  Offline OP
Carlisle, AR.
1971 charger
factory cruise control turn signal switch with extra 3 wire plug. need to know what the 3 wire plug connects to?
service manual shows nothing. any ideas?
mike
1970 Challenger T/A
1970 Roadrunner RM21 Vcode
1971 Gtx
1971 Satellite
1971 Charger 500 GB5 383 A54 car
1972 Satellite
1997 Dodge 1500 hunting rig
2014 Ram 2500 Mega Cab
Re: cruise control turn signal switch [Re: mdwyer] #2654774
05/12/19 09:39 PM
05/12/19 09:39 PM
Chilly Northern, Minn.
71 Charger R/T Offline
Could you post a picture of the "extra three wire plug"? I don't recall any additional plug. If my memory serves me right, there was only the one 4 conductor plug. I have factory cruise on my '71 Charger that I can take reference pictures of if needed.
Re: cruise control turn signal switch [Re: 71 Charger R/T] #2654800
05/12/19 10:36 PM
05/12/19 10:36 PM
Carlisle, AR.
mdwyer Offline OP
mdwyer  Offline OP
Carlisle, AR.
I have the cruise harness with the 4 pin from turn signal stalk hooked up but the car has an additional 3 pin plug from the turn signal switch. Original switch plus one i bought years ago had the extra plug and it said it was for cruise. i'll have to get a picture.
thanks,
mike
1970 Challenger T/A
1971 Gtx
1971 Satellite
1972 Satellite
Re: cruise control turn signal switch [Re: mdwyer] #2654806
05/12/19 10:44 PM
05/12/19 10:44 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
thanks,
mike
Sounds like your turn signal switch has the extra plug for the cornering lamps on C-bodies . Its what the original switch supersedes to via Mopar
Cruise control wiring is a separate overlay harness , it does NOT go thru the turn signal switch itself or its wiring harness
Re: cruise control turn signal switch [Re: gtx6970] #2654920
05/13/19 10:29 AM
05/13/19 10:29 AM
Carlisle, AR.
mdwyer Offline OP
mdwyer  Offline OP
Carlisle, AR.
perfect! thanks for everyone help.
mike
1970 Challenger T/A
1971 Gtx
1971 Satellite
1972 Satellite
