Best thread sealant for fuel fittings. #2654125
05/10/19 07:12 PM
05/10/19 07:12 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
What seems to be the best sealant for sealing fuel fittings? I've read good things about the Permatex Aviation Form-A-Gasket No. 3 Sealant. Are there any better options out there? The fittings on my fuel pressure regulator have a tiny leak and I need to seal them up before something catches on fire.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Best thread sealant for fuel fittings. [Re: 73cuda340] #2654133
05/10/19 07:34 PM
05/10/19 07:34 PM
robertop Offline
robertop  Offline
I have recently used Locktite thread sealant stick, that comes in a paste form and cannot clog fuel lines. So far so good.
Re: Best thread sealant for fuel fittings. [Re: robertop] #2654160
05/10/19 08:47 PM
05/10/19 08:47 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
What about this?
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Best thread sealant for fuel fittings. [Re: 73cuda340] #2654162
05/10/19 09:03 PM
05/10/19 09:03 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Will not leak after using this stuff.... But.... It's a [censored] if you have to take it apart after is sets up... But your fitting will not leak, For Sure....
https://www.zoro.com/permatex-pipe-joint-compound-16-oz-black-80045/i/G1623693/
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Best thread sealant for fuel fittings. [Re: racerhog] #2654182
05/10/19 10:01 PM
05/10/19 10:01 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I've had good luck with this on my brake and fuel fittings.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Best thread sealant for fuel fittings. [Re: 73cuda340] #2654206
05/10/19 11:27 PM
05/10/19 11:27 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Fuel fittings shouldn't need any type of sealant, they all are metal to metal crush type 45 degree seals. If they are tight enough they seal....Otherwise on hose to line connections double up the hose clamps if you want to be extra safe.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Best thread sealant for fuel fittings. [Re: HemiRick] #2654217
05/11/19 12:46 AM
05/11/19 12:46 AM
DuPont, Washington
DZJim Offline
DZJim  Offline
DuPont, Washington
Like he sez...no sealant. Its a metal-to-metal situation. You maybe able to glue together low pressure liquid or gaseous connections and prevent a leak, Try that with 3,000psi aircraft hydraulic systems? or, even your wife's gas clothes dryer...read the install instruction...NO sealer/glue/compound/etc. on the flare fitting.
Re: Best thread sealant for fuel fittings. [Re: 73cuda340] #2654222
05/11/19 02:20 AM
05/11/19 02:20 AM
There are two different standard types of fittings used on fuel systems in America, National Pipe Thread,NPT, and inverted flare. Pipe thread usually need a pipe sealer, inverted flares do not tsk
Learn on how to identify them now and make your life easier in the future scope up
Re: Best thread sealant for fuel fittings. [Re: Cab_Burge] #2654276
05/11/19 10:16 AM
05/11/19 10:16 AM
moparx Online content
moparx  Online Content
like cab says, NO sealant on flared fittings ! taper pipe needs sealant. i use loctite 567. it works with gasoline and oils, plus, it also acts as a thread galling preventer.
beer
Re: Best thread sealant for fuel fittings. [Re: Cab_Burge] #2654281
05/11/19 10:19 AM
05/11/19 10:19 AM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
I'm using the Permatex Aviation this week when I put in the new AVS2 Carb. The Holley pressure regulator and the carb inlet hard line both have NPT threads. The fuel system is not the place to screw around with marginal or inappropriate sealants.
Re: Best thread sealant for fuel fittings. [Re: gzig5] #2654292
05/11/19 10:57 AM
05/11/19 10:57 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Re: Best thread sealant for fuel fittings. [Re: 6PakBee] #2654441
05/11/19 10:16 PM
05/11/19 10:16 PM
clarks summit pa
clarks summit pa
I have one of the Holley Hp billet regulators with NPT fittings, so no flare fittings.
Re: Best thread sealant for fuel fittings. [Re: 73cuda340] #2654534
05/12/19 10:43 AM
05/12/19 10:43 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I must be OLD! I still have a few rolls of teflon tape............ whistling Most of my fitting these days are AN.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Best thread sealant for fuel fittings. [Re: 6PakBee] #2654611
05/12/19 01:12 PM
05/12/19 01:12 PM
Originally Posted by 6PakBee
that is also very good. up i intend to go to that when my 567 supply is done.
beer
Re: Best thread sealant for fuel fittings. [Re: 73cuda340] #2654615
05/12/19 01:21 PM
05/12/19 01:21 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Having spent several years in positions that dealt with high to ultra high vacuum chambers, loctite became my friend when trying to seal pipe thread connections. If it won't let a helium molecule through at 10-8 torr its not going to leak period. I used the hardening types due to the out-gassing of the paste types twocents beer
