FACTORY 340 PISTON #2653960
05/10/19 10:07 AM
05/10/19 10:07 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Is the factory high compression piston flat or domed?
Re: FACTORY 340 PISTON [Re: A/MP] #2653965
05/10/19 10:17 AM
05/10/19 10:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I know that the MP pistons are domed.. I dont know what you mean
with "factory high comp"
wave
Re: FACTORY 340 PISTON [Re: MR_P_BODY] #2653997
05/10/19 11:32 AM
05/10/19 11:32 AM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
By "factory high compression" I assume you mean '68-'71 OE stuff. Flat tops with valve relief eyebrows.
Re: FACTORY 340 PISTON [Re: CMcAllister] #2654057
05/10/19 02:48 PM
05/10/19 02:48 PM
FL
moparwizard Offline
moparwizard  Offline
FL
1970 340
Re: FACTORY 340 PISTON [Re: moparwizard] #2654070
05/10/19 03:19 PM
05/10/19 03:19 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Early 340 pistons had a slight dome and required a different Edelbrock head for it to clear. In 1972 the compression dropped
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: FACTORY 340 PISTON [Re: pittsburghracer] #2654085
05/10/19 04:56 PM
05/10/19 04:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What am I looking at on the cyl wall of mainly on 4 and 6.. is that some
sort of reflection or what shruggy
wave
Re: FACTORY 340 PISTON [Re: MR_P_BODY] #2654089
05/10/19 05:13 PM
05/10/19 05:13 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Is it just like the factory 10.5 piston style that was used for the 273? 2 valve reliefs with a little dome.
Re: FACTORY 340 PISTON [Re: A/MP] #2654097
05/10/19 05:55 PM
05/10/19 05:55 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
I thought they were a flat top with the eyebrows, .020" above deck, but no dome?
Re: FACTORY 340 PISTON [Re: gzig5] #2654116
05/10/19 06:47 PM
05/10/19 06:47 PM
PA.
"Little"John
"Little"John
PA.
Technically a flat top dome with a small chamfer that sticks above the block. I used to have a couple of sets but I must have sold them.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: FACTORY 340 PISTON [Re: pittsburghracer] #2654202
05/10/19 11:17 PM
05/10/19 11:17 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
Having started racing 71 and 72 340's in stock eliminator back when stock factory pistons were required I have a few sets. The 71 pistons at blueprint specs were .045 above deck with an .028 gasket and had 2 valve notches.The 72 and later pistons were .054 down in the block with a .032 gasket and 4 notches. With the 71 at specs and the head at 63.3 cc's the eyebrow above the intake valve would kiss the piston and the valve notches were not deep enough for the cam. It took some massaging to get everything to fit.
Real Men shift for themselves
Re: FACTORY 340 PISTON [Re: 1DGEMAN] #2654232
05/11/19 06:35 AM
05/11/19 06:35 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
The main drawback with the early 340 piston is the weight........seriously heavy !
Re: FACTORY 340 PISTON [Re: Mcode69] #2654236
05/11/19 07:07 AM
05/11/19 07:07 AM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
Even the low comp pistons are heavy. Only the 360 had light pistons.
Re: FACTORY 340 PISTON [Re: gzig5] #2655436
05/14/19 05:03 PM
05/14/19 05:03 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
That what i have seen with the 340s i have taken apart. I have factory 273 pistons, they nothing like a 340 piston.
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: FACTORY 340 PISTON [Re: 65signet] #2655439
05/14/19 05:19 PM
05/14/19 05:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You guys are talking factory stock pistons.. all I ever use for my 340s are
aftermarket pistons.. I use nothing except the block and MAYBE the crank
every thing else is aftermarket or MP stuff
wave
Re: FACTORY 340 PISTON [Re: MR_P_BODY] #2655511
05/14/19 08:31 PM
05/14/19 08:31 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
I found, on my shelf, some forged , standard bore 340 pistons. The box said flat top. Don't have a part# so I'm just trying to see what the factory piston looked like and what my cylinder head options might be.
Re: FACTORY 340 PISTON [Re: A/MP] #2655715
05/15/19 02:42 PM
05/15/19 02:42 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
That is going to depend on where they are going to end up in relation to the deck. Above, flush, or in the hole. You can't tell that by looking at them, you need to measure pin center to top and do some math. If they are above deck, the head design needs to accommodate that.
