Re: FACTORY 340 PISTON
[Re: MR_P_BODY]
#2653997
05/10/19 11:32 AM
05/10/19 11:32 AM
Posts: 11,552 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
By "factory high compression" I assume you mean '68-'71 OE stuff. Flat tops with valve relief eyebrows.
[Re: moparwizard]
#2654070
05/10/19 03:19 PM
05/10/19 03:19 PM
Posts: 20,173 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Early 340 pistons had a slight dome and required a different Edelbrock head for it to clear. In 1972 the compression dropped
[Re: gzig5]
#2654116
05/10/19 06:47 PM
05/10/19 06:47 PM
Posts: 20,173 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I thought they were a flat top with the eyebrows, .020" above deck, but no dome? Technically a flat top dome with a small chamfer that sticks above the block. I used to have a couple of sets but I must have sold them.
[Re: pittsburghracer]
#2654202
05/10/19 11:17 PM
05/10/19 11:17 PM
Posts: 606 TN
1DGEMAN
TN
Having started racing 71 and 72 340's in stock eliminator back when stock factory pistons were required I have a few sets. The 71 pistons at blueprint specs were .045 above deck with an .028 gasket and had 2 valve notches.The 72 and later pistons were .054 down in the block with a .032 gasket and 4 notches. With the 71 at specs and the head at 63.3 cc's the eyebrow above the intake valve would kiss the piston and the valve notches were not deep enough for the cam. It took some massaging to get everything to fit.
Real Men shift for themselves
[Re: Mcode69]
#2654236
05/11/19 07:07 AM
05/11/19 07:07 AM
Posts: 606 TN
1DGEMAN
TN
Even the low comp pistons are heavy. Only the 360 had light pistons.
[Re: gzig5]
#2655436
05/14/19 05:03 PM
05/14/19 05:03 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
I thought they were a flat top with the eyebrows, .020" above deck, but no dome? That what i have seen with the 340s i have taken apart. I have factory 273 pistons, they nothing like a 340 piston.
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: 65signet]
#2655439
05/14/19 05:19 PM
05/14/19 05:19 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I thought they were a flat top with the eyebrows, .020" above deck, but no dome? That what i have seen with the 340s i have taken apart. I have factory 273 pistons, they nothing like a 340 piston. You guys are talking factory stock pistons.. all I ever use for my 340s are aftermarket pistons.. I use nothing except the block and MAYBE the crank every thing else is aftermarket or MP stuff
