Flat cam break in oil, again
#2653844
05/09/19 09:40 PM
05/09/19 09:40 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
Getting close to firing my engine with the fresh flat tappet cam and Howard's says to fill the engine with light oil 5-20 or 10-30 non-synthetic oil for break-in. They also want you to use their ZPM break-in lube as well. I have broke-in a few cams in my life but their procedure is new to me. They suggest run it at 2500 for 10 minutes then let it cool down then run it again for another 10 minutes. I've never used a Howard's cam before, just Comp,Crane, and purple cams. They don't say to remove the inner springs but I always have with solids so I'm going to break-in with just the outer springs. I'm just guessing here but maybe there is more splash on the cam with a lighter oil I have EDM lifters and my springs are 145 on the seat and 350 on the nose. Any thoughts on this procedure? I have never marked my lifters to see if they turn with the cam but I will this time I will while I'm lashing the valves. I usually just make sure they spin when I drop them in the bores. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Flat cam break in oil, again
[Re: fourgearsavoy]
#2653854
05/09/19 10:06 PM
05/09/19 10:06 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
Gus , Just done this on my new motor I use Brad Penn break in oil . Its a 30 mineral with Comp additive . 30 minutes , then change it out . Outer springs only . Now have Brad Penn 40 mineral for a couple of weeks , change to BP 20/50 next week before racing 18th
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: fourgearsavoy]
#2653860
05/09/19 10:32 PM
05/09/19 10:32 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
I followed this procedure a few years back when installing a Howard's cam and everything turned out OK. I believe that I used Comp's break-in additive with some 10W30 (either Brad Penn or Valvoline VR1 oil, I can't remember which). Removing the inner springs probably wouldn't be a bad idea. Just don't rush things and rev too high too quickly.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: 1968RR]
#2653881
05/09/19 11:36 PM
05/09/19 11:36 PM
Posts: 20,789 A collage of whims
topside
A collage of whims
The last couple of FT BBs I used Lucas in one & Gibbs in the other, left the inner springs in. Set everything (full bowls, timing) so they started right away, varied the RPM around 1500-2500 for about 20 minutes, watched everything like a hawk of course. Let 'em cool off, pull oil filter & cut open, replace & refill, run again if I felt I wanted to mess with something. Zero problems either one, both still running great. Not huge cams, kinda "hot-street" with about 400# over the nose. If Howard's has a proprietary additive and you're concerned about their stuff, I'd use it just to avoid an argument if something goes wrong.
[Re: fourgearsavoy]
#2653889
05/10/19 12:56 AM
05/10/19 12:56 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I ran the light weight oil with good amount of zink in it and I run zink all the time but less of it.. break it in the way they say to.. the thinner oil helps.. parts move easier with it.. I did run it for 20 mins
[Re: fourgearsavoy]
#2653920
05/10/19 07:39 AM
05/10/19 07:39 AM
Posts: 17,846 S.E. Michigan
ZIPPY
S.E. Michigan
The additive I like to use has these properties:
Zinc: 4898 ppm (4700ppm) Phosphorus: 4921 ppm (4300ppm) Calcium: 4279 ppm (7800ppm)
Unfortunately it isn't available any longer over the counter, I'm relying on a stash.... but there are plenty of good ones out there.
Their direction to go for 10 minutes, cool down and another 10 minutes is good. My last one (a mopar performance hydraulic, everyone's favorite!) I did between 5 and 7 minute intervals, and did it like 5 or 6 times. As long as you eventually get to the 20+ to 30 minute mark and keep enough rpm in it for splash and decent lifter rotation you're good. There's a little less stress doing it in smaller time increments.
Oil grade and brand....might as well be politics or religion...... I feel the most confident with sae 30 or 40 single grade but only because that is all I ever used since my first build, not because I'm a lubrication engineer.
Remember the low end of the multiple viscosity scale (typically 0w, 5w and 10w) is a rating based on viscosity at freezing temperature. If...during your break in....your ambient temp will be, for instance, 75 degrees, I guarantee the oil will not be flowing as a 5w or 10W would. It will be somewhere between the low and high end of the scale.
Verify your lifter rotation and oil flow to all the parts before the intake is bolted on....good luck
Rich H.
Esse Quam Videri
[Re: earlymopar]
#2653931
05/10/19 08:17 AM
05/10/19 08:17 AM
ZIPPY
S.E. Michigan
Mock up with oil only. Put a dot of white or bright colored paint on the top edge of each lifter Leave the spark plugs out Turn over with a socket on the crankshaft Watch the paint marks No rotation=it's going to be eaten in short order...repair by swapping or replacing lifters When satisfied with rotation pull the cam out and coat lightly with assembly lube but don't use any on the sides of the lifters.
Also if you have access to 2-3 sets of lifters, feeler gauges and a surface plate, sometimes it's possible to identify those with less crown on the face than others and send them back. Less crown usually means less rotation, but it's also relative to lobe taper as well which is a little more difficult to measure. I did go through two sets of lifters on the last one, to arrive at one set that I felt had sufficient crown.
Some don't agree with me including a few professionals I respect highly....and that is cool....this is just my own angle on it....
Rich H.
Esse Quam Videri
[Re: fourgearsavoy]
#2653933
05/10/19 08:26 AM
05/10/19 08:26 AM
Posts: 4,206 New York
polyspheric
New York
Funny remark from another BBS: "About oil viscosity numbers: the first number (low temperature) is the time in seconds it takes for oil pressure to reach the last rod bearing. 5W: 5 seconds, 20W: 20 seconds, straight 50: 50 seconds.” Not science, but the trend is there."
Boffin Emeritus
[Re: moparx]
#2654050
05/10/19 02:25 PM
05/10/19 02:25 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
I used the Joe Gibbs 15/50 break in oil to break in my solid FT. I was also advised to leave in the break in oil for a while (maybe 100 miles), as opposed to draining it immediately. My engine is not new, just new cam and lifters. So far, so good.
2 kids and a dog
[Re: sgcuda]
#2654141
05/10/19 07:53 PM
05/10/19 07:53 PM
Posts: 614 Michigan
Get-X
I am used to running rollers, but I am building a hydraulic cam motor for a friend. Are you supposed to always use zinc additive after break in? After the first 1,000 miles or so, is it ok just to run a synthetic oil like Mobil 1 or Castrol Syntec without zinc additive? It's always going to need the zinc whether it's in the oil being used or added to the oil without zinc.
'65 Belvedere '68 GTX '57 Dodge pickup
[Re: Get-X]
#2654145
05/10/19 08:18 PM
05/10/19 08:18 PM
fourgearsavoy
Rittman Ohio
So here's my plan, just use 5-30 regular oil to set the lash and make sure the lifters are turning in the bores. Then pull the rockers off and coat the lifters and cam lobes with break-in lube before I put the valley plate cover and intake back on. Next pull the inner springs and re-assemble the valvetrain and get it ready to run. I already have the carb and intake dialed in and idle set at 2300 with the old cam so i know it will run with that deal with only minor adjustments. The only thing I'm actually changing is the cam,lifters,and springs. I picked up the LSM spring tool and It looks like a nice tool and I cant wait to use it. I have to work all day tomorrow so I might have to get it together Sunday. I never had any issues with break in the old way I was just the light oil and 10 minute intervals that had me questioning Howard's instructions but I'm gonna use their guidelines and I should have a good result. Thanks Gus
[Re: MR_P_BODY]
#2654748
05/12/19 08:27 PM
05/12/19 08:27 PM
Posts: 48 Minnesota, USA
minnesota guy
Minnesota, USA
Mopar guys--Read up on an Oil blog/site by "540ratguy" Need for a lot of Zinc is a myth. He tested 230 oils and keeps doing tests based on their PSI. He ranks them. The best of the hot rod oils is Joe GIbbs, but only a moderate performer. He is a chevy guy, ugghh, but after taking out 2 cams breaking them in a couple years ago, I went searching. He has 2 sites. One is blogging with questions for him and the other is more details on the ranked oils, zinc discussions, etc...There are 3-4 oils I will ever run now. Mobil 1 0w-40....QS 5w-30 Full synthetic...Amsoil 5w-30 Signature series (the best oil by far he has ever tested today..years ago they were mid pack)……..and other is Valvoline High mileage Full Synthetic 5w-30...…………Most likely never take a cam out with these oils and you do not need to use break in oil first (a crock) or add any zinc.... He shows tests on plenty of oils where break in zinc has been added and ruined the chemistry and wear protection of the oil. He saw 5w-30 oil is all you ever need as long as you have HI-volume oil pump. His testing shows oil runs cooler, does more lubricating and getting back to pan faster. -He is not sponsored by any oil company.
It is a good read and you make up your own minds! I am breaking in my 493 6 pack FAST motor right now with M-1 0w-40 (it ranked top 5 oils or so on psi testing) and then I am switching to Amsoil Signature series 5w-30 as it ranked #1 by far against any oil...I have never used Amsoil before or even untwisted one of their oil caps..
You should see all the high priced so called racing oils ranking near the bottom. To each is own to decide.
[Re: minnesota guy]
#2654828
05/13/19 01:09 AM
05/13/19 01:09 AM
Posts: 636 Graz, Austria
DGS
Graz, Austria
You should see all the high priced so called racing oils ranking near the bottom. To each is own to decide. do a google search on the 540rat guy before you trust him blindly... He even admits that his testing does not simulate what's going on in a running engine.
