M/T ET drag radials slipping on rims #2653082
05/07/19 05:36 PM
05/07/19 05:36 PM
California
70Drop Offline OP
70Drop  Offline OP
California
I put a set of Mickey Thompson ET Drag radials (9x30) on my Duster last season. They tended to move about an inch on each run. That didn't stop even after about 10 runs. One of the tires started leaking air at the bead after a run, so I dismounted the tires. The beads weren't damaged. I read that some people are glueing the beads to the rims with Permatex High Tack. So I did that when I put the tires back on. The tires are still spinning about an inch on the rims after 7 runs with the High Tack. I feel like I want to put bead screws in, but everyone (including M/T) says you can't do that on radials. So what's a poor racer supposed to do? Bead locks are expensive. Why is it that I can't use bead screws? Everybody says so, but nobody ever says why
Re: M/T ET drag radials slipping on rims [Re: 70Drop] #2653085
05/07/19 05:53 PM
05/07/19 05:53 PM
Renton Washington
Triple Threat Offline
Renton Washington
How fast is the car and how much air pressure are you running?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: M/T ET drag radials slipping on rims [Re: 70Drop] #2653088
05/07/19 05:59 PM
05/07/19 05:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you cant stop them from moving then put the screws in.. I have my
DR glued on and they havent moved.. whats your tire pressure at..
you might want to up that some.. you know they arent moving now
wave
Re: M/T ET drag radials slipping on rims [Re: Triple Threat] #2653090
05/07/19 06:01 PM
05/07/19 06:01 PM
California
70Drop Offline OP
70Drop  Offline OP
California
10.60, 1.5 60-ft., 3300 lbs. The tires like 15 lbs of pressure. More than that and they spin
Re: M/T ET drag radials slipping on rims [Re: 70Drop] #2653216
05/07/19 10:53 PM
05/07/19 10:53 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
Was a post on yellow bullet on the screws.
Tears the bead up .
What I go is clean bead on tire and wheel .
Then glue both .
Put 30 psi in the tires for a couple days before I bring them down to the proper PSI .
Re: M/T ET drag radials slipping on rims [Re: a493demon] #2653291
05/08/19 08:38 AM
05/08/19 08:38 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The Yellow Bullet threads were interesting. One or two guys had ripped the bead out of their radials with screws while others reported that they had done it for years with no problems.
https://www.yellowbullet.com/forum/showthread.php?t=144867
https://www.yellowbullet.com/forum/showthread.php?t=159200
Master, again and still
Re: M/T ET drag radials slipping on rims [Re: 70Drop] #2653298
05/08/19 09:12 AM
05/08/19 09:12 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
WHAT SIZE TIRE?
WHAT WIDTH RIM?
WHAT AIR PRESSURE?
....BAD A$$ STREET CAR.....
Re: M/T ET drag radials slipping on rims [Re: 70Drop] #2653309
05/08/19 09:35 AM
05/08/19 09:35 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I had bead sealer put on mine but I have very few miles
Re: M/T ET drag radials slipping on rims [Re: Clanton] #2653317
05/08/19 09:55 AM
05/08/19 09:55 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
There have been so many posts on this subject but guys insist on taking shortcuts. It’s a step by step process and the best results take 2-3 days. There is no way in heck you should have issues with a 9 inch tire if you do the proper steps.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: M/T ET drag radials slipping on rims [Re: 70Drop] #2653360
05/08/19 11:26 AM
05/08/19 11:26 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I suspect it's the low air pressure you use. Most radial users I know run 18-22 psi and the higher pressure seems to reduce the tire rotating on the wheel.
Maybe your chassis settings aren't optimized for a radial, which requires you to run lower pressure as a Band-Aid for the chassis.
Re: M/T ET drag radials slipping on rims [Re: BradH] #2653492
05/08/19 07:59 PM
05/08/19 07:59 PM
California
70Drop Offline OP
70Drop  Offline OP
California
That's exactly what I'm thinking. I've ordered mono leafs and shocks from Calvert. Hopefully that will help. Mazzolini thinks so.
The glue cured on the rim/tire for over a month before I raced. I put plenty of High Tack on both the rim and the bead and waited until it tacked before joining them. I don't think I did anything wrong.
Re: M/T ET drag radials slipping on rims [Re: 70Drop] #2653537
05/08/19 10:50 PM
05/08/19 10:50 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run M/T bias at 13.5 psi glued with tubes as well. 3345lbs, 1.25 60 ft. They haven't moved more than about 1" in 85 passes.
Doug
Re: M/T ET drag radials slipping on rims [Re: dvw] #2653621
05/09/19 09:43 AM
05/09/19 09:43 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I also run the MT 10.5W on a 12 inch rim.They moved some then stopped work
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
